Web Performance Monitor
Let’s get your product installed and configured!
We offer our Self-Led Onboarding program so that you have quick access to a project plan, video walkthroughs, and quick links to the technical documentation for the installation and configuration of your products. We also offer a comprehensive documentation library should you need more information related to your product.
SolarWinds Academy Training and eLearning
Discover THWACK®
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 200,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
Upgrade Tools and Information
Upgrade Advisor
SolarWinds Product Upgrade Advisor
Check the compatibility of your Orion Products here. Certain installation and upgrade scenarios may not be available.
You’ll be able to select your current Operating System, Database, and product versions you have currently installed to see if you are compatible with new versions.
Next Product Category
- Upgrade AdvisorSolarWinds Product Upgrade AdvisorUpgrade Advisor
