How to secure SQL variables used in Orion Platform
In the SolarWinds® Orion® Platform 2020.2.1 Hotfix 2, a new setting to improve the security of SQL macros was introduced. On fresh installs, this setting is enabled by default. On upgrades, you need to enable it manually. SolarWinds worked with our security, product, and engineering teams to fix the vulnerability CVE-2020-27869.
Note: Using this setting requires Administrator privileges.
SolarWinds would like to thank our Security Researchers for reporting on the issue in a responsible manner and working with our security, product, and engineering teams to fix the vulnerability:
- CVE-2020-27869
Components of the Select statement
A regular SELECT query including the regular select list components.
A regular FROM clause including one or more table or view names.
A regular WHERE clause.
An optional GROUP BY clause.
An optional HAVING clause.
Clauses disabled for SQL in the Orion Platform by MacroParser-isSecuringSQLMacroEnabled
ORDER BY (except when a TOP clause is specified)
INTO
OPTION clause with query hints
FOR BROWSE
How to enable / disable MacroParser-isSecuringSQLMacroEnabled
- Open your database in the Orion Database Manager. Use Database Manager to view the SolarWinds database.
Find the MacroParser-isSecuringSQLMacroEnabled setting in the Settings table:
To enable the security macro, set CurrentValue to 1.
To disable the security macro, set CurrentValue to 0.
Restart Alerting Engine v2 and Module Engine. See Start and stop Orion services.
How to debug and troubleshoot MacroParser-isSecuringSQLMacroEnabled
You can regulate the logging level using the MacroParsing section in the Log Adjuster tool. See Adjust logging levels with the SolarWinds Log Adjuster.
The relevant lines in the MacroParser log look as follows:
2020-11-09 15:48:25,395 [23] DEBUG SolarWinds.Orion.Core.Common.MacroParsing.MacroParser - (null) Getting SecureSQLMacroEnabled setting from DB... 2020-11-09 15:48:25,395 [23] DEBUG SolarWinds.Orion.Core.Common.MacroParsing.MacroParser - (null) Secure SQL macro turned : ON ... 2020-11-09 15:50:31,321 [12] DEBUG SolarWinds.Orion.Core.Common.MacroParsing.MacroParser - (null) Parsing common macros SQL: SELECT top 1 Caption From Nodes... 2020-11-09 15:50:31,321 [12] DEBUG SolarWinds
