Tools
APPE FTP command
A client issue the APPE command after successfully establishing a data connection when it wishes to upload data to the server. The client provides the file name it wishes to use for the upload. If the file already exists on the server, the data is appended to the existing file. If the file does not exist, it is created.
10/25/2018 8:41 PM
10/25/2018 8:41 PM
This article explains the use of the Append [with create] (APPE) FTP command.
Common responses
