Tools
502 FTP response code
A 502 code may be sent in response to any FTP command that the server does not support. It is a permanent negative reply, which means the client is discouraged from sending the command again since the server will respond with the same reply code. The original FTP specification dictates a minimum implementation for all FTP servers with a list of required commands. Because of this, a 502 reply code should not be sent in response to a required command.
Example response
502 Command not implemented
Possible command
A 502 response code may be sent to any FTP command that the server does not support.
