Tools
226 FTP response code
This article explains why the 226 FTP reply code is sent. A 226 reply code is sent by the server before closing the data connection after successfully processing the previous client command affecting the data connection. In most cases, it signals the completion of a file transfer. It can also be sent in response to the ABOR command, which signals that the current file transfer was successfully terminated.
10/24/2018 8:31 PM
10/24/2018 8:31 PM
This article explains why the 226 FTP response code is sent.
Example response
226 Closing data connection.
Possible commands
