Submit a ticketCall us
AnnouncementsSystem Monitoring for Dummies
Tired of monitoring failures disrupting the system, application, and service? Learn the key monitoring concepts needed to help you create sophisticated monitoring and alerting strategies that can help you save time and money. Read the eBook.
Get your free eBook.
Home > Success Center > Storage Resource Monitor (SRM)
SRM storage management software lets you do multi-vendor storage performance and capacity monitoring right! Use simple to understand dashboard views of multiple storage devices from EMC, NetApp, IBM, and others. A detailed view into storage arrays, RAID groups, and LUNs makes it easier for you to identify storage performance problems quickly and fix them faster. Save time and money with Storage Resource Monitor’s automatic capacity forecasting feature. Make informed decisions using out-of-the-box reporting to help eliminate assumption-driven conclusions. Seamlessly integrate with other SolarWinds products to provide a comprehensive picture of IT health. Learn more about SRM.
Last modified
Tags
Classifications
Public
