Applications Systems
Self-Led Project Plan for Storage Resource Monitor
This article provides a step-by-step guide for self-led onboarding of SolarWinds Storage Resource Monitor (SRM). It covers installation, array configuration, licensing, performance monitoring, alerting, reporting, and integration with the SolarWinds Platform tools to help you gain visibility into your storage infrastructure.
8/14/2025 6:46 PM
8/20/2025 5:06 PM
Installation & Setup
Install SolarWinds Platform products in a new environment
Installation Guide
System Requirements
Storage Array Management
Add Storage Arrays
Learn how to add and configure storage arrays for monitoring.
Add your storage array for monitoring with SRM
Add additional arrays
Supported Arrays
Check compatibility for arrays A–H and I–Z.
Supported arrays (A - H)
Supported arrays (I - Z)
Test Storage Array Connectivity
After adding arrays, verify polling status and ensure data collection is functioning.
Manage Storage Objects
Explore and manage storage objects in the SRM web console.
Explore your SRM environment
Licensing & Polling
License SRM
Understand licensing best practices for storage arrays.
Licensing Storage Resource Monitor (SRM)
Customize Polling
Edit storage object properties and polling frequencies.
Edit storage object properties in SRM
Edit array polling frequencies
Views & Widgets
SRM Summary & Details
Log in to the SolarWinds Platform Web Console and explore SRM views.
Views and widgets in SRM
SRM widgets
Storage Controller Monitoring
Monitor storage controllers and configure thresholds.
Storage Controller monitoring
Hardware Health
Monitor Hardware Health
Enable and monitor health for supported devices.
Monitor hardware health for SRM
Enable hardware health monitoring for SRM
Alerts & Troubleshooting
Manage Thresholds
Configure static and dynamic thresholds for storage objects.
Manage thresholds for SRM
Set SRM thresholds
Set SRM thresholds for specific storage objects
SRM Alerts
Troubleshoot Arrays
Resolve issues with unreachable arrays.
Troubleshoot an unreachable array in SRM
Reporting & Capacity Planning
SRM Reports
Generate reports for arrays, NAS, storage polls, and LUNs.
Run reports in SRM
Schedule Reports
Automate report delivery to stakeholders using the report scheduler.
Create and assign report schedules for the SolarWinds Platform in Report Manager
Capacity Planning
SolarWinds Platform Integration
PerfStack & AppStack
Visualize performance and relationships across infrastructure.
Use PerfStack with SRM
Investigate a performance issue using AppStack
Advanced Configuration
Backup & Restore Configuration
Back up SRM configuration settings before major changes or upgrades.
Custom Properties & Grouping
Use custom properties and groups to organize and filter storage objects.
Notes
