Not able see newly created custom property in Orion web console
This article provide information about an the issue "Not able see newly created custom property in Orion web console"
2. Restart the Orion Services on the Main poller and the Polling engine that is showing Last DB sync in Red.
3. If that does not help Shutdown Solarwinds Server(s) > Shutdown the Orion DB SQL server > Reboot the SQL server > Restart the Orion Server(s) in the order.
4. If issue still persists after server restart then follow this KB article below for troubleshooting Database Maintenance Overdue.
