Worldwide map are not showing and displaying grey background
The worldwide widget displaying grey background same thing going to manage map.
12/22/2021 4:31 PM
6/1/2023 3:07 PM
On the Orion home summary page World wide map widget displaying grey background. See screenshot below:
Network Performance Monitor
Resolution 1:
  1. Disable UAC.
  2. Run Permission Checker and repair any failed checks.
  3. Shutdown All Orion services using the Orion Service Manager.
  4. Repair the Information Service.
  5. Run the Orion Configuration Wizard.
  6. Open the Orion Web Console and confirm whether the map is displayed.
Resolution 2:
