Tools
Troubleshooting PostgreSQL database upgrade issues after upgrading to Web Help Desk versions 12.7.7 and above
This article shows the troubleshooting path when encountering issues with PostgreSQL database upgrade for Web Help Desk version 12.7.7 and above
3/25/2022 3:23 PM
3/25/2022 3:23 PM
Beginning in Web Help Desk version 12.7.7, PostgreSQL 13.3 will be required for all Web Help Desk deployments due to security improvements.
All Web Help Desk deployments from version 12.3 to 12.7.6 will have an embedded PostgreSQL database version 9.x.
The upgrade process in version 12.7.7 will convert PostgreSQL version 9 to version 13.3
Note:
It is required to upgrade to Web Help Desk version 12.7.7 first, before going to version 12.7.8.
See this Upgrade Path documentation
Web Help Desk
Pre-requisites:
Troubleshooting Guide:
Note:
If you upgraded from version 12.7.6 or older to version 12.7.8, it is best to restore to a previous backup or server snapshot, then upgrade to version 12.7.7 first before going to 12.7.8.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
