Applications Systems
Transactions are unknown - Location not responding
Location is not reponding but appears green in the web console. Transactions are showing gray / unknown status in the webconsole. Unable to get agent details from agent.
Error in the SEUMJobs.log (C:\ProgramData\SolarWinds\Logs\SEUM\)
ERROR SolarWinds.SEUM.Jobs.AgentDetailsController - Unable to get agent details from agent. SolarWinds.SEUM.Jobs.AgentClientException: Location Not Responding. at SolarWinds.SEUM.Jobs.AgentClient.GetHttpResponse(String api, String method, Stream dataStream, String contentType, Dictionary`2 customHeaders) at SolarWinds.SEUM.Jobs.AgentClient.GetHttpResponse(String api, String method, Dictionary`2 postVariables, Dictionary`2 customHeaders) at SolarWinds.SEUM.Jobs.AgentClient.GetAgentDetails() at SolarWinds.SEUM.Jobs.AgentDetailsController.Execute(AgentJobSettings settings)
To determine which polling engine the Player Location is assigned to; go to Settings > All Settings > WPM Settings > Manage Player Locations > select the Player of interest and click Edit > Expand the Advanced section to view the assigned poller in the dropdown.
Please note: This will bring down polling services for the duration of the Configuration Wizard.
- RDP to the polling engine.
- Open 'Programs & Features'.
- Right click the Solarwinds Web Performance Monitor vX.X. - NOTE: be sure you're repairing the main application and not the Playback Player or the Recorder.
- This will automatically launch the Configuration Wizard. If it does not, launch the Configuration Wizard located in the Start Menu under SolarWinds Orion.
- Once the Configuration Wizard is complete, open the Orion web console and check the status of your transactions and/or player location(s).
