Tools
Subscribe to iCalendar when running Web Help Desk over https:// only
Subscribe to iCalendar and Outlook when running Web Help Desk over https:// for OSX.
iCal and Outlook 2007 both support subscriptions over https. But since OS X and Windows are not set up to hand off https:// URLs to the calendar application, you must configure the subscription manually.
For iCal only:
- In iCal, right-click Subscription and select Copy Link Location.
- Create a new subscribed calendar and paste the link location into the https:// subscription URL in the provided field.
For iCal and Outlook 2007 and later:
- In iCal, right-click Subscription and select Copy Link Location as described in the previous process description.
- Paste the link location into the address bar of your web browser.
Note: You must use Firefox, Chrome or Safari. Internet Explorer does not work for this procedure. - Change the protocol in the URL from https:// to webcals:// and press Return. This action sends the request to Outlook, where it can confirm your subscription request.
