Self-Led Project Plan for Netflow Traffic Analyzer
This article provides a step-by-step guide for self-led onboarding of SolarWinds NetFlow Traffic Analyzer (NTA). It includes installation, integration with the SolarWinds Platform, NetFlow and CBQoS configuration, IP address group management, flow navigation, reporting, alerting, and use case scenarios to help you analyze network traffic, identify performance issues, and optimize bandwidth utilization effectively.
Installation & Setup
Install SolarWinds Platform Products
Install the required SolarWinds Platform products in a new environment before configuring NTA.
SolarWinds Platform Installation Guide
NetFlow Configuration
Set Up Network Devices to Export NetFlow Data
Configure network devices to export NetFlow data to NTA.
Set Up Devices to Export NetFlow Data
Device Configuration Examples
Use vendor-specific configuration examples for exporting flows.
Manage Flow Sources & CBQoS Devices
Add, edit, and maintain flow sources and CBQoS devices in NTA.
Configure Flow Sources & CBQoS Devices
Configure Applications & Service Ports
Set up monitored applications and ports for traffic analysis.
NTA Report – Ports/Application Name
Enable/Disable Port Monitoring
CBQoS Settings
Enable and monitor CBQoS data dynamically.
View CBQoS Data
Monitor CBQoS Dynamically
Monitoring & Settings
IP Address Groups
Create, edit, and delete IP address groups for traffic segmentation.
Manage IP Address Groups
Edit IP Address Groups
Delete IP Address Groups
Retention Settings
Maintain and optimize NTA Flow Storage database performance.
Flow Storage Database Maintenance
Using NTA & Flow Navigator
View NetFlow Summary & Details
Access NTA data in the SolarWinds Platform Web Console for traffic insights.
View NTA Data in the SolarWinds Platform Web Console
Flow Navigator Filters
Create and use Flow Navigator filters to analyze specific traffic patterns.
Flow Requirements
Flow Storage Database Settings
Use Flow Navigator
Filtered Views
Save custom Flow Navigator views and assign them to menu bars.
Create Custom Views
Reports & Analytics
Add NetFlow Resources to Views
Incorporate NetFlow resources into SolarWinds Platform web views.
NTA Reports
Review, create, and edit reports for flow data.
Best Practices for NTA Reports
Edit NTA Reports
CBQoS Reports
Generate and review historical CBQoS reports.
Historical CBQoS Reports
Alerts & Actions
Flow Alerts
Create quick flow alerts from the NTA summary page.
Configure Flow Alerts
Advanced NTA Alerts
Set up and customize advanced alerting for NTA.
Advanced NTA Alerts
Use Case Scenarios
Investigate High Bandwidth Utilization
Identify causes of excessive bandwidth usage.
Find the Cause of High Bandwidth Usage
Track Traffic by Site
Monitor site-specific traffic patterns.
Best Practices & Enhancements
Notes
- This plan is designed for customers who prefer a self-paced onboarding experience.
- For assisted onboarding, refer to SolarWinds Deployment Services.
- For troubleshooting, contact SolarWinds Support.
