Palo Alto device does not show all IP Addresses in the All IP Addresses resource
The All IP Address resource is not populated in the Node Details - Summary page for some Palo Alto devices.
10/31/2018 10:39 PM
9/16/2022 3:55 PM
The All IP Address resource is not populated for some Palo Alto devices.
This can also affect NTA by causing DEBUG log entries such as:
 [Flow Listener on port ####] DEBUG SolarWinds.Netflow.Processing.PacketSourceResolver - Ignoring NetFlow packet from unknown IP Address xx.xx.xx.xx
[35] DEBUG SolarWinds.Netflow.Processing.Events.FlowSourceStatusEventHandler - Raising event Unknown Flow Source for IP Address xx.xx.xx.xx for the #### time.
Network Performance Monitor
The device may not be reporting the missing IP addresses on the expected OID.
Orion collects this information using 1.3.6.1.2.1.4.20 (ipAddrTable) and may not be supported by some Palo Alto devices.
You can verify if the information is being returned using using the SNMP Walk tool - SolarWinds SNMP Walk: A new tool for collecting SNMP MIB walks.
If the information is not listed for that OID, you can contact Palo Alto about that behavior.
