NTA NetFlow Receiver Service flow processing is suspended due to licensing issues. License status check failed: no valid license were found for OSS
NetFlow Receiver Service flow processing is suspended due to licensing issues. License status check failed: no valid license were found for OSS. You may find that the Netflow service is unable to start and immediately stops when trying to start the service again via the Orion Service Manager. When checking the Windows Event Viewer, you can find the following message types: X/X/XXXX X:XX AM/PM Event Type NetFlow Receiver Service flow processing is suspended due to licensing issues.
X/X/XXXX X:XX AM/PM Event Type NetFlow Receiver Service flow processing is suspended due to licensing issues. X/X/XXXX X:XX AM/PM Event Type License status check failed: no valid license were found for OSS. X/X/XXXX X:XX AM/PM Event Type NetFlow Receiver Service [OSS] Stopped
You may also observe the error below from nta businesslayer logs:
ERROR SolarWinds.Netflow.Common.Licensing.Licensing - Unable to get license. SolarWinds.Orion.Core.Common.ModuleLicenseException: License is expired or not available at SolarWinds.Orion.Core.Common.ModuleLicense.CheckLicense() at SolarWinds.Netflow.Common.Licensing.Licensing.GetModuleLicense(String applicationName, Version productVersion, String productVersionSpecification, Int32 licenseVersion) at SolarWinds.Netflow.Common.Licensing.Licensing.GetLicense()
