NTM fails to start (no errors)
This article provides information about the issue when after installing NTM, double-clicking NTM does not start the application.
10/12/2018 7:36 PM
4/1/2019 3:26 PM
Network Topology Mapper
This can occur if NTM is not able to access the registry and see license information.
To confirm this is the issue:
1. Open the following file in notepad: C:\ProgramData\SolarWinds\Network Topology Mapper\Logs\SolarWinds.Client.log
2. Look for the following error:
LicenseProvider - Failed to get license. Exception: System.Security.SecurityException: Requested registry access is not allowed.
To resolve this issue, right-click the NTM application and click Run as Administrator.
Optionally, you can also complete the procedures below:
  1. Reset an Orion Platform product license using License Manager
  2. Right-click the NTM application, and click Properties.
  3. Click the Compatibility tab.
  4. Select Run as administrator.
  5. Click OK.
