Reset an Orion Platform product license using License Manager
This article describes how to use SolarWinds License Manager to migrate or upgrade an Orion Platform product license without contacting SolarWinds Customer Support. This article applies to SolarWinds products running on Microsoft operating systems with the .NET Framework.
2/4/2019 3:27 PM
2/4/2019 3:27 PM
Products not supported by License Manager
You cannot use License Manager to migrate or upgrade product licenses on the following products, as these products have their own internal licensor. See the individual product page for information about license management.
Prerequisites
The following needs must be satisfied in order to successfully run SolarWinds License Manager. Please note that you must have active maintenance on your products in order to use the License Manager.
NEEDREQUIREMENT
Installation LocationThe same computer as the products to be migrated
ConnectivityInternet access
Microsoft .Net Framework
v2.0 or later
Links to the framework are included in the installation.
Operating System
Windows® 2000 SP4 with Update Rollup 1 or later
Windows Server® 2003 SP1 and higher, including R2 (32-bit & 64-bit)
Windows XP®
Windows Vista®
Browser
Internet Explorer® 6 or later
Firefox® 2.0 or later
Orion Platform
If you are unable to use License Manager for your license resets, submit a ticket through your Customer Portal or to SolarWinds Customer Support. Include the following information in the ticket:
  • Computer name
  • License key
  • Type of license
  • Number of seats to reset (for multi-activation only)
  • Reason you are unable to reset the license
Install License Manager
  1. Identify the computer with the SolarWinds license you want to reset, upgrade, or migrate to another system.
  2. Ensure that the system time is within 24 hours in either direction from Greenwich Mean Time (© 1995-2017 Greenwich2000, available at https://greenwichmeantime.com/, obtained on March 21, 2017.). Otherwise, you cannot reset your license.
    The time zone settings do not affect or cause this issue.
  3. Install License Manager on the system.
    1. Log into the Customer Portal to download License Manager.
    2. Unzip the downloaded file.
    3. Review the enclosed PDF for additional information.
  4. Double-click LicenseManager.exe.
    The License Manager interface is displayed.
  5. Run License Manager online or offline based on the Internet connection to the server hosting your product license.
This section describes how to reset a SolarWinds product license where the license is stored on system that is connected to the Internet.
Deactivate an installed license
  1. Start the License Manager from the SolarWinds Program group.
  2. Check the products you want to deactivate on this computer.
  3. Click Deactivate.
    The license is deactivated and available for activation on a new computer
Reactivate a license on another system
  1. Log on to the system that will host your product license.
  2. When prompted, provide your license information.
  3. Follow the prompts on your screen to compete the reactivation process.
    When completed, the license you deactivated on a previous system is assigned to this system.
Upgrade an installed license
  2. In the Action column, click Upgrade next to the product licenses you want to upgrade as licensed products on this system.
  3. Complete the Activation Wizard to upgrade your license.
Activate an installed evaluation and license the product
  2. In the Action column, click Activate next to the products you want to register as licensed products on this system.
Run License Manager offline
This section describes how to reset a SolarWinds product license offline where the license is stored on system that is not connected to the Internet.
See Deactivate and reset licenses in License Manager and in the SolarWinds Customer Portal  for details.
This procedure describes how to deactivate and reset a SolarWinds or DameWare product license in License Manager and the Customer Portal.
Deactivate a SolarWinds license
  1. Open License Manager.
  2. Select your product and click Deactivate.
    You can deactivate more than one product at the same time. In this case, the deactivation file will contain information about each product.
    In some products running Microsoft Windows and the .NET FrameWork, you can deactivate licenses using the internal licensing tool of the product.
  3. Complete the deactivation wizard.
  4. Save the deactivation file.
  5. Log in to the SolarWinds Customer Portal.
  6. Click License Management > License Management.
  7. Select your product instance and click Deactivate license manually.
  8. On the Manage License Deactivation page, browse for the deactivation file you created in License Manager and click Upload.
    Your SolarWinds license is deactivated.
Deactivate and reset a DameWare license
This section describes how to deactivate and reset a seat-based DameWare license:
  1. Log in to the SolarWinds Customer Portal.
  2. Click License Management > License Management.
  3. Select your DameWare instance, and then click Deactivate license manually.
  4. On the Manage License Deactivation page, click I don't have access to the machine with the SolarWinds product.
  5. On the Deactivate License page, click Reset License.
  6. Select the appropriate computer, and then click Reset License again.
You can reset the license of more than one machine at the same time.
Activate or upgrade an installed or evaluation license
This section describes how to manually register a SolarWinds license.
  1. Click Start > All Programs > SolarWinds Orion > Advanced Features > SolarWinds License Manager.
  2. When prompted to enter license information, select This server does not have internet access. Guide me through offline, manual activation and click Next.
  3. Click Copy Unique Machine ID.
  4. Paste the Unique Machine ID onto your preferred text editor.
    Change the Font to FixedSys to differentiate l, I and 1 as well as 0 and O.
  5. Log in to the Customer Portal on a machine with internet access.
  6. Go to Licensing and Maintenance > License Management.
  7. Expand the list item for your product and click Activate license manually.
  8. Enter your user and computer details, then paste the Unique Machine ID from your text editor into the appropriate field.
  9. Click Generate Key.
  10. Download your license file and save it to a safe location.
  11. Repeat Steps 1 and 2 in this procedure.
  12. In the Activate product (no internet connection) window, proceed to the last step by browsing to the license file you saved in Step 10.
  13. Click Next and complete the license registration.
Reset an ipMonitor license
You can reset your ipMonitor verstion 9.x.x license by launching the ipMonitor Configuration Program, clicking Software Licensing, and selecting Park License.
To reset your ipMonitor version 10.x and greater, contact SolarWinds Customer Support .
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
