Monitor VPN user connection sessions in NPM
Make a widget, alert or report showing the total amount of users connected through a VPN device.
This is often used to monitor employee connections to an internal business network while they are working from home.
While widgets that monitor real-time VPN user connections can be turned into reports, these reports are not historical and no options in alerting currently exist to keep track of the VPN user session amount.
Currently, alerts and historical reports for a number of active VPN connections can only be created through a UnDP.
More information on Alert and report setup can be found in the Pro content section of this article.
