Applications Systems
How to Repair WPM
Repairing Web Performance Monitor. How to repair the module WPM on the main polling engine and additional polling engines. Transactions not playing, unknown, or down with a specific error.
- RDP to the polling engine.
- Open 'Programs & Features'.
- Right click the Solarwinds Web Performance Monitor vX.X. - NOTE: be sure you're repairing the main application and not the Playback Player or the Recorder.
- This will automatically launch the Configuration Wizard. If it does not, launch the Configuration Wizard located in the Start Menu under SolarWinds Orion.
- Once the Configuration Wizard is complete, open the Orion web console and check the status of your transactions and/or player location(s).
• Transactions Unknown, Player not responding: The remote server returned an error: (400) Bad Request
• All Transactions are unknown on a specific player location in WPM
• Transactions are unknown - Location not responding
• WPM Transactions are unknown
