Guide to SolarWinds Product Licenses
This article will direct you to information regarding the licensing tiers, and license activation and management process for each product.
11/19/2018 3:13 AM
4/16/2026 10:15 PM
This article will direct you to information regarding the licensing tiers, and license activation and management process for each SolarWinds product.
SolarWinds Platform products support subscription licenses. See License types in the SolarWinds Platform help for details.
Finding license keys
License keys for most products can be found by logging into the Customer Portal and selecting Licenses > Manage Licenses. SolarWinds Backup licenses are not in the Customer Portal, they are sent via email.
If you do not see your license listed in the Customer Portal and did not receive an email, please contact Customer Service.
Orion Platform
Updated: April 15, 2026
ARMSolarWinds Observability Self-Hosted Essentials (SWOSH)
DamewareNPM
DPASAM
DREIPAM
ETSLA
Kiwi CatToolsUDT
Kiwi Log ViewerVNQM
Kiwi Syslog ServerSolarWinds Observability Self-Hosted Advanced (SWOSH)
NTMNTA
Patch ManagerNCM
SEMVMAN
Serv-USCM
SQL SentryScalability Engines
SWO SaaSHA
SWSDSolarWinds Observability Self-Hosted Enterprise Scale (SWOSH)
Task FactoryEOC
WHDSolarWinds Platform
NAM
SRM
WPM
Access Rights Manager (ARM)
Existing customers
Existing customers can continue to use the existing license model unchanged to the existing extent (8MATES). Within the scope of the valid maintenance, updates can continue to be installed and used. In order to extend the scope of functions (upgrade), a switch to the new license model is required.
General licensing information
Access Rights Manager is licensed by the number of enabled accounts in Active Directory (including all enabled AD user accounts and service accounts).
Managing your license
For license activation, see Activate your Access Rights Manager License in the ARM Getting Started Guide. To update an ARM license, see Update the ARM license.
Trial licenses
You can download a free trial version of ARM here. The trial version contains a license that is automatically activated by the installation itself. The trial license is valid for 30 days from the date of installation and is subject to the following restrictions:
  • The number of rows in the reports is limited.
  • The number of change actions that can be executed is limited.
For more information, see the latest release notes.
Dameware
Dameware has both stand-alone and centralized versions. See Dameware stand-alone licensing or Dameware centralized licensing for details.
Managing your licenses
Dameware licenses can be activated during installation and managed with the stand-alone SolarWinds License Manager.  For more information, see Activate a Dameware license in the Dameware Installation Guide.
If you no longer have access to the machine running Dameware, your license can be deactivated manually in the Customer Portal. See Manually deactivate a DameWare or ETS license in the Customer Portal.
Database Performance Analyzer (DPA)
For general information on licensing DPA, see DPA licensing in the DPA Administrator Guide. Please note that DPA has different categories of license for monitoring different types of databases. See License types for more information.
See Activate DPA licenses and Allocate or deallocate DPA licenses  in the DPA Administrator Guide.
Dameware Remote Everywhere (DRE)
For general information on licensing DRE, see DRE Licensing.
Engineer's Toolset (ETS)
For more information about licensing for ETS, see Engineer's Toolset v11.0 licensing (FAQ).
Engineer's Toolset licenses with the same expiration date and that show as not activated can be merged into a single license. For more information, see Merge Engineers Toolset License Keys (FAQ) and License Management in the Customer Portal.
If you no longer have access to the machine running ETS, your license can be deactivated manually in the Customer Portal. See Manually deactivate a Dameware or ETS license in the Customer Portal.
Engineer's Toolset for Desktop
ETS for Desktop licenses can be activated during product installation. For more information, see Install Desktop Engineer's Toolset.
Engineer's Toolset on the Web
Enterprise Operations Console (EOC)
See SolarWinds SolarWinds Platform product licensing.
High Availability (HA)
For information on activating HA licenses, see Activate High Availability pool licenses in the SolarWinds Platform Administrator Guide.
IP Address Manager (IPAM)
To learn about the different IPAM licenses available, see IPAM licensing and deployment in the IPAM Installation Guide.
Kiwi CatTools
See Enter a Kiwi CatTools license key in the Kiwi CatTools Installation Guide.
Kiwi Log Viewer
See Apply a Kiwi Log Viewer license.
Kiwi Syslog Server
See Enter a Kiwi Syslog Server license key in the Kiwi Syslog Server Installation Guide.
Security Event Manager (SEM), formerly Log & Event Manager (LEM)
See Choose a licensing method for your SEM deployment in the SEM Installation Guide.
To activate a license, see SEM license activation. To update a license, see Update the SEM License.
Log Analyzer (LA)
For an explanation of what consumes LA licenses, see LA Licensing in the Log Analyzer Administrator Guide.
Network Automation Manager (NAM)
Your SolarWinds NAM license is a bulk license for NPM, NCM, NTA, VNQM, IPAM, UDT, and SolarWinds High Availability (HA). Network Automation Manager is licensed on the number of nodes that are monitored. A node is defined as a unique network device including, but not limited to, routers, switches, firewalls, and wireless controllers and access points.
See also information on HA licensing and on Scalability Engines licensing.
Netflow Traffic Analyzer (NTA)
See SolarWinds NTA licensing for the types of licenses currently available.
See NCM licensing model in the NCM Administrator Guide.
See NPM licensing for information on NPM license tiers.
Network Topology Mapper (NTM)
NTM licenses can be activated during installation or using the stand-alone SolarWinds License Manager tool. The stand-alone License Manager is also used for managing NTM licenses after activation. For more information, see Install a production copy of NTM  and Activate licenses with License Manager.
Patch Manager
See Patch Manager Licensing to learn how Patch Manager is licensed.
See Activate the Patch Manager license in the Patch Manager Installation Guide.
Scalability Engines
Additional Polling Engine (APE)
For information on assigning licenses to polling engines, see Assign Licenses in the SolarWinds Platform Administrator Guide. For information on activating stackable licenses, see Activate stackable poller licenses.
Additional Web Server (AWS)
For information on activating licenses, see Activate Licenses in the SolarWinds Platform Administrator Guide. For information on evaluating AWS when you have a commercial APE license, see Evaluate SolarWinds Platform products.
Server & Application Monitor (SAM)
See SAM licensing model in the SAM Administrator Guide. SAM Licensing FAQs provide additional details.
To learn how SAM licenses are impacted if multiple SolarWinds Platform modules are deployed see How your SAM license relates to other SolarWinds Platform module licenses.
Server Configuration Monitor (SCM)
See SCM licensing in the SCM Administrator Guide.
Serv-U MFT Server, Serv-U FTP Server, & Serv-U Gateway
Note: Serv-U Licenses now Available in Customer Portal. If your license was purchased prior to July 27, 2016, locate your activation email or contact Customer Service for assistance.
For information on registering Serv-U MFT, FTP, or Gateway, see Register the Serv-U MFT license key. To deactivate a license, see Deactivate a license in Serv-U.
SQL Sentry
See SQL Sentry License Management.
Storage Resource Monitor (SRM)
SRM license levels apply to the number of hard drives and solid state drives across all Shared Storage (SAN, NAS) systems rather than nodes. For more information, please see Licensing SRM in the SRM Administrator Guide.
SolarWinds Observability (SWO) SaaS
For general information on licensing SWO SaaS, see SWO SaaS Subscription.
SolarWinds Service Desk
For general information on licensing SWSD, see Licenses for ESM Customers.
Task Factory
See Task Factory Licensing.
User Device Tracker (UDT)
See UDT licensing information for information on UDT license tiers.
Virtualization Manager (VMAN)
See VMAN licensing information for information on VMAN license types.
VoIP Network Quality Manager (VNQM)
See VNQM licensing and deployment for information on VNQM license types.
Web Help Desk (WHD)
See Product Licensing in the WHD Installation Guide for information on WHD license tiers.
See Activate your license in the Web Help Desk Administrator Guide.
Web Performance Monitor (WPM)
Licensing for many SolarWinds Platform products is based on the amount of nodes monitored. WPM licensing is based on the number of transactions assigned to transaction locations that host a WPM Player. Also called "player locations," transaction locations may be on the main Orion server or on remote servers that connect to the Orion server.
WPM is licensed by the total number of transactions implemented, regardless of whether transactions are managed or unmanaged. The number of licenses used is calculated by multiplying the number of recordings by the number of locations assigned, as shown in these examples.
  • 5 transactions at 1 location = 5 licenses
  • 5 transactions at 3 locations = 15 licenses
LICENSE TIER
IMPLEMENTED TRANSACTIONS
LICENSE
WPM5
5
License with 1st-year maintenance
WPM10
10
WPM20
20
WPM50
50
WPM100
100
WPM200
200
License with 1st-Year maintenance
WPMX
Unlimited, standard playback rate
