Error "Could not get installer metadata from administration service on main polling engine." while running installation or upgrade
Could not get installer metadata from administration service on main polling engine. Please contact SolarWinds support
- SolarWinds Administration Service not running on Main poller
- Insufficient disk space on the Server where installer is run.
- Networking issues (i.e. slow connection, security measures) between Main poller and the Scalability engines (Pollers / Additional webservers)
- Wrong Version of Solarwinds Administration Service Registry on main poller's pointing to wrong version or path
- Log in to the main polling engine.
- Open the Orion Service Manager.
- Restart the SolarWinds Administration Service.
- Attempt installation again.
Solution for Cause 2:
- Adjust (increase) free space on the boot disk (C:) and drive on which Orion is installed (default C:)
Solution for Cause 3:
- Download full package (Offline Installer) from the Customer Portal.
- Attempt installation using downloaded package.
Please follow the steps in the KB Scalability Engine installation failed with exception when getting installer metadata (solarwinds.com)
