Applications Systems
Difference in Hardware Health monitoring by manufacturer and polling method for physical servers in SAM
This article provides information on the different vendors and polling methods used when polling Hardware Health on physical servers. Depending on the device manufacturer, you may need to install additional software from third-party vendors.
11/29/2018 10:29 PM
5/11/2026 11:48 PM
This article describes how data gathered by SAM's Hardware Health Monitoring feature varies based on the polling method used and the server manufacturer.
Before proceeding with this article, review these sections of the SAM Administrator Guide:
See also the following sections of the Orion Platform Administrator Guide:
Server Application Monitor
For the latest information about supported devices, polling methods, and operating systems, see Hardware health monitoring requirements
This article includes the following sections:
  • Data collected based on vendor and polling method
  • HP
    • HP SNMP Poller OIDs
    • HP WMI Classes
  • Dell
    • Dell SNMP Poller OIDs
    • Dell WMI Classes
  • IBM
    • IBM SNMP Poller OIDs
    • IBM WMI Classes
  • Verifying Source Data on the Server
    • Verify SNMP OIDs using snmpwalk
    • Verify WMI Pollers using WBEMTEST
This table shows the Hardware Health data that SAM can gather from monitored servers, based on polling method and manufacturer.
Manufacturer
Polling method
Chassis
Temp.
Fan
Disk
PS
CPU
Intrusion
Memory
Array
Battery
Cisco UCSICMPYesYesYesYesYesYesYesYesNoYes
Nutanix CLIYesYesYesYesYesYesNoYesYesNo
HP
WMI
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
No
No
HP
SNMP
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
Dell
WMI
Yes
Yes
Yes
No
Yes
Yes
No
Yes
No
No
Dell
SNMP
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
IBM
WMI
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
IBM
SNMP
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
No
VMware
CIM poller
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
vCenter
API
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
  • Polling a Windows machine using a Windows Agent is the same with WMI.
  • Polling a Linux machine using a Linux Agent is the same with SNMP.
SNMP OIDs and WMI Classes used for Polling
HP
HP SNMP Poller OIDs
Chassis:
OID = CPQSISYSSERIALNUM
1.3.6.1.4.1.232.2.2.2.1
OID = cpqSiProductName
1.3.6.1.4.1.232.2.2.4.2
Power Supply:
OID = CPQHEFLTTOLPOWERSUPPLYCHASSIS
1.3.6.1.4.1.232.6.2.9.3.1.1
OID = cpqHeFltTolPowerSupplyCondition
1.3.6.1.4.1.232.6.2.9.3.1.4
OID = cpqHeFltTolPowerSupplyMainVoltage
1.3.6.1.4.1.232.6.2.9.3.1.6
OID = cpqHeFltTolPowerSupplyCapacityUsed
1.3.6.1.4.1.232.6.2.9.3.1.7
OID = cpqHeFltTolPowerSupplyModel
1.3.6.1.4.1.232.6.2.9.3.1.10
OID = cpqHeFltTolPowerSupplySerialNumber
1.3.6.1.4.1.232.6.2.9.3.1.11
Power Meter:
OID = CPQHEPOWERMETERSUPPORT
1.3.6.1.4.1.232.6.2.15.1
OID = cpqHePowerMeterCurrReading
1.3.6.1.4.1.232.6.2.15.3
Memory:
OID = CPQSIMEMBOARDINDEX
1.3.6.1.4.1.232.2.2.4.5.1.1
OID = cpqSiMemModuleSize
1.3.6.1.4.1.232.2.2.4.5.1.3
OID = cpqSiMemModuleSerialNo
1.3.6.1.4.1.232.2.2.4.5.1.10
OID = cpqHeResMemBoardIndex
1.3.6.1.4.1.232.6.2.14.11.1.1
OID = cpqHeResMemModuleCondition
1.3.6.1.4.1.232.6.2.14.11.1.5
Temperature:
OID = CPQHETEMPERATURECHASSIS
1.3.6.1.4.1.232.6.2.6.8.1.1
OID = cpqHeTemperatureLocale
1.3.6.1.4.1.232.6.2.6.8.1.3
OID = cpqHeTemperatureCelsius
1.3.6.1.4.1.232.6.2.6.8.1.4
OID = cpqHeTemperatureCondition
1.3.6.1.4.1.232.6.2.6.8.1.6
Fan:
OID = CPQHEFLTTOLFANCHASSIS
1.3.6.1.4.1.232.6.2.6.7.1.1
OID = cpqHeFltTolFanIndex
1.3.6.1.4.1.232.6.2.6.7.1.2
OID = cpqHeFltTolFanLocale
1.3.6.1.4.1.232.6.2.6.7.1.3
OID = cpqHeFltTolFanPresent
1.3.6.1.4.1.232.6.2.6.7.1.4
OID = cpqHeFltTolFanType
1.3.6.1.4.1.232.6.2.6.7.1.5
OID = cpqHeFltTolFanCondition
1.3.6.1.4.1.232.6.2.6.7.1.9
OID = cpqHeFltTolFanCurrentSpeed
1.3.6.1.4.1.232.6.2.6.7.1.12
Cpu:
OID = CPQSECPUUNITINDEX
1.3.6.1.4.1.232.1.2.2.1.1.1
OID = cpqSeCpuName
1.3.6.1.4.1.232.1.2.2.1.1.3
OID = cpqSeCpuStatus
1.3.6.1.4.1.232.1.2.2.1.1.6
OID = cpqSeCpuDesigner
1.3.6.1.4.1.232.1.2.2.1.1.8
OID = cpqSeCpuSocketNumber
1.3.6.1.4.1.232.1.2.2.1.1.9
Disk:
OID = CPQIDEATADISKCONTROLLERINDEX
1.3.6.1.4.1.232.14.2.4.1.1.1
OID = cpqIdeAtaDiskModel
1.3.6.1.4.1.232.14.2.4.1.1.3
OID = cpqIdeAtaDiskSerialNumber
1.3.6.1.4.1.232.14.2.4.1.1.5
OID = cpqIdeAtaDiskCondition
1.3.6.1.4.1.232.14.2.4.1.1.7
OID = cpqIdeAtaDiskCapacity
1.3.6.1.4.1.232.14.2.4.1.1.8
OID = cpqIdeAtaDiskOsName
1.3.6.1.4.1.232.14.2.4.1.1.15
OID = cpqDaPhyDrvCntlrIndex
1.3.6.1.4.1.232.3.2.5.1.1.1
OID = cpqDaPhyDrvIndex
1.3.6.1.4.1.232.3.2.5.1.1.2
OID = cpqDaPhyDrvModel
1.3.6.1.4.1.232.3.2.5.1.1.3
OID = cpqDaPhyDrvStatus
1.3.6.1.4.1.232.3.2.5.1.1.6
OID = cpqDaPhyDrvSize
1.3.6.1.4.1.232.3.2.5.1.1.45
OID = cpqDaPhyDrvSerialNum
1.3.6.1.4.1.232.3.2.5.1.1.51
OID = cpqDaPhyDrvLocationString
1.3.6.1.4.1.232.3.2.5.1.1.64
Raid controller:
OID = CPQDACNTLRINDEX
1.3.6.1.4.1.232.3.2.2.1.1.1
OID = cpqDaCntlrModel
1.3.6.1.4.1.232.3.2.2.1.1.2
OID = cpqDaCntlrBoardCondition
1.3.6.1.4.1.232.3.2.2.1.1.12
OID = cpqDaCntlrSerialNumber
1.3.6.1.4.1.232.3.2.2.1.1.15
Raid Logical Drives:
OID = CPQDALOGDRVCNTLRINDEX
1.3.6.1.4.1.232.3.2.3.1.1.1
OID = cpqDaLogDrvIndex
1.3.6.1.4.1.232.3.2.3.1.1.2
OID = cpqDaLogDrvSize
1.3.6.1.4.1.232.3.2.3.1.1.9
OID = cpqDaLogDrvCondition
1.3.6.1.4.1.232.3.2.3.1.1.11
OID = cpqDaLogDrvOsName
1.3.6.1.4.1.232.3.2.3.1.1.14
Battery:
OID = CPQDAACCELCNTLRINDEX
1.3.6.1.4.1.232.3.2.2.2.1.1
OID = cpqDaAccelBattery
1.3.6.1.4.1.232.3.2.2.2.1.6
HP WMI poller:
HP WMI Classes are polled from "root\HPQ" namespace:
  • CIM_Chassis
  • CIM_NumericSensor ( server from lab we use for testing is returning in this instance only temperature sensors. I am not sure if this will be common or is just this one machine case)
  • HP_WinFan ( added to polling because NumericSensor returns only temperature sensor values)
  • CIM_DiskDrive (HD sensor which do not return HealthState or Status)
  • CIM_PowerSupply ( this class is returning not instances for lab server we use)
  • HP_Processor - CPU information
  • HP_MemoryModule – Memory information
Note: To verify that the data a server is providing is available, use WBEMTEST on the Orion Server, as described at the end of this article.
Dell
Chassis:
OID = CHASSISMANUFACTURERNAME
1.3.6.1.4.1.674.10892.1.300.10.1.8
OID = chassisModelName
1.3.6.1.4.1.674.10892.1.300.10.1.9
OID = chassisServiceTagName
1.3.6.1.4.1.674.10892.1.300.10.1.11
OID = cpqSiSysSerialNum
Power Supply:
OID = POWERSUPPLYCHASSISINDEX
1.3.6.1.4.1.674.10892.1.600.12.1.1
OID = powerSupplyStatus
1.3.6.1.4.1.674.10892.1.600.12.1.5
OID = powerSupplyOutputWatts
1.3.6.1.4.1.674.10892.1.600.12.1.6
OID = powerSupplyType
1.3.6.1.4.1.674.10892.1.600.12.1.7
OID = powerSupplyLocationName
1.3.6.1.4.1.674.10892.1.600.12.1.8
Voltage:
OID = VOLTAGEPROBECHASSISINDEX
1.3.6.1.4.1.674.10892.1.600.20.1.1
OID = voltageProbeStatus
1.3.6.1.4.1.674.10892.1.600.20.1.5
OID = voltageProbeReading
1.3.6.1.4.1.674.10892.1.600.20.1.6
OID = voltageProbeType
1.3.6.1.4.1.674.10892.1.600.20.1.7
OID = voltageProbeLocationName
1.3.6.1.4.1.674.10892.1.600.20.1.8
OID = voltageProbeDiscreteReading
1.3.6.1.4.1.674.10892.1.600.20.1.16
Amperage:
OID = AMPERAGEPROBECHASSISINDEX
1.3.6.1.4.1.674.10892.1.600.30.1.1
OID = amperageProbeStatus
1.3.6.1.4.1.674.10892.1.600.30.1.5
OID = amperageProbeReading
1.3.6.1.4.1.674.10892.1.600.30.1.6
OID = amperageProbeType
1.3.6.1.4.1.674.10892.1.600.30.1.7
OID = amperageProbeLocationName
1.3.6.1.4.1.674.10892.1.600.30.1.8
OID = amperageProbeDiscreteReading
1.3.6.1.4.1.674.10892.1.600.30.1.16
Memory:
OID = MEMORYDEVICECHASSISINDEX
1.3.6.1.4.1.674.10892.1.1100.50.1.1
OID = memoryDeviceStatus
1.3.6.1.4.1.674.10892.1.1100.50.1.5
OID = memoryDeviceLocationName
1.3.6.1.4.1.674.10892.1.1100.50.1.8
OID = memoryDeviceSize
1.3.6.1.4.1.674.10892.1.1100.50.1.14
OID = memoryDeviceSerialNumberName
1.3.6.1.4.1.674.10892.1.1100.50.1.23
Temperature:
OID = TEMPERATUREPROBECHASSISINDEX
1.3.6.1.4.1.674.10892.1.700.20.1.1
OID = temperatureProbeStatus
1.3.6.1.4.1.674.10892.1.700.20.1.5
OID = temperatureProbeReading
1.3.6.1.4.1.674.10892.1.700.20.1.6
OID = temperatureProbeType
1.3.6.1.4.1.674.10892.1.700.20.1.7
OID = temperatureProbeLocationName
1.3.6.1.4.1.674.10892.1.700.20.1.8
Fan:
OID = COOLINGDEVICECHASSISINDEX
1.3.6.1.4.1.674.10892.1.700.12.1.1
OID = coolingDeviceStatus
1.3.6.1.4.1.674.10892.1.700.12.1.5
OID = coolingDeviceReading
1.3.6.1.4.1.674.10892.1.700.12.1.6
OID = coolingDeviceType
1.3.6.1.4.1.674.10892.1.700.12.1.7
OID = coolingDeviceLocationName
1.3.6.1.4.1.674.10892.1.700.12.1.8
Cpu:
OID = PROCESSORDEVICECHASSISINDEX
1.3.6.1.4.1.674.10892.1.1100.30.1.1
OID = processorDeviceIndex
1.3.6.1.4.1.674.10892.1.1100.30.1.2
OID = processorDeviceStatus
1.3.6.1.4.1.674.10892.1.1100.30.1.5
OID = processorDeviceVersionName
1.3.6.1.4.1.674.10892.1.1100.30.1.16
Disk:
OID = ARRAYDISKNUMBER
1.3.6.1.4.1.674.10893.1.20.130.4.1.1
OID = arrayDiskName
1.3.6.1.4.1.674.10893.1.20.130.4.1.2
OID = arrayDiskSerialNo
1.3.6.1.4.1.674.10893.1.20.130.4.1.7
OID = arrayDiskLengthInMB
1.3.6.1.4.1.674.10893.1.20.130.4.1.11
OID = arrayDiskComponentStatus
1.3.6.1.4.1.674.10893.1.20.130.4.1.14
Raid controller:
OID = CONTROLLERNUMBER
1.3.6.1.4.1.674.10893.1.20.130.1.1.1
OID = controllerName
1.3.6.1.4.1.674.10893.1.20.130.1.1.2
OID = controllerComponentStatus
1.3.6.1.4.1.674.10893.1.20.130.1.1.38
Chassis Intrusion:
OID = SYSTEMSTATECHASSISINTRUSIONSTATUSCOMBINED
1.3.6.1.4.1.674.10892.1.200.10.1.30
Battery:
OID = BATTERYCHASSISINDEX
1.3.6.1.4.1.674.10892.1.600.50.1.1
OID = batteryIndex
1.3.6.1.4.1.674.10892.1.600.50.1.2
OID = batteryStatus
1.3.6.1.4.1.674.10892.1.600.50.1.5
OID = batteryLocationName
1.3.6.1.4.1.674.10892.1.600.50.1.7
Dell WMI poller
Dell WMI Classes are polled from the "root\cimv2\dell" namespace:
  • CIM_Chassis
  • CIM_Tachometer - Fans
  • CIM_TemperatureSensor - Temperature
  • DELL_PowerConsumptionWattsSensor - PoweSupply
  • DELL_PowerConsumptionAmpsSensor - PoweSupply
  • CIM_VoltageSensor - PoweSupply
  • CIM_Processor
  • CIM_PhysicalMemory
To verify the data a server is providing is available use WBEMTEST on the Orion Server. Steps at then end of the document.
IBM
Chassis:
OID = IBMPSGCOMPUTERSYSTEMDETAILSKEYINDEX
1.3.6.1.4.1.2.6.159.1.1.60.3.1.1
OID = iBMPSGComputerSystemDetailsModel
1.3.6.1.4.1.2.6.159.1.1.60.3.1.8
OID = iBMPSGComputerSystemDetailsSerialNumber
1.3.6.1.4.1.2.6.159.1.1.60.3.1.10
Power Supply:
OID = IBMPSGVOLTAGESENSORKEYINDEX
1.3.6.1.4.1.2.6.159.1.1.80.2.1.1
OID = iBMPSGVoltageSensorCurrentReading
1.3.6.1.4.1.2.6.159.1.1.80.2.1.2
OID = iBMPSGVoltageSensorStatus
1.3.6.1.4.1.2.6.159.1.1.80.2.1.21
Memory:
OID = IBMSYSTEMPHYSICALMEMORYKEYINDEX
1.3.6.1.4.1.2.6.159.1.1.120.1.1.1
OID = ibmSystemPhysicalMemoryCapacity
1.3.6.1.4.1.2.6.159.1.1.120.1.1.11
OID = ibmSystemPhysicalMemoryBankLabel
1.3.6.1.4.1.2.6.159.1.1.120.1.1.12
OID = ibmSystemPhysicalMemorySerialNumber
1.3.6.1.4.1.2.6.159.1.1.120.1.1.16
OID = ibmSystemPhysicalMemoryStatus
1.3.6.1.4.1.2.6.159.1.1.120.1.1.17
Temperature:
OID = IBMPSGTEMPERATURESENSORKEYINDEX
1.3.6.1.4.1.2.6.159.1.1.80.1.1.1
OID = iBMPSGTemperatureSensorCurrentReading
1.3.6.1.4.1.2.6.159.1.1.80.1.1.2
OID = iBMPSGTemperatureSensorStatus
1.3.6.1.4.1.2.6.159.1.1.80.1.1.21
Fan:
OID = IBMPSGTACHOMETERKEYINDEX
1.3.6.1.4.1.2.6.159.1.1.80.5.1.1
OID = iBMPSGTachometerCurrentReading
1.3.6.1.4.1.2.6.159.1.1.80.5.1.2
OID = iBMPSGTachometerStatus
1.3.6.1.4.1.2.6.159.1.1.80.5.1.20
Cpu:
OID = IBMSYSTEMPROCESSORKEYINDEX
1.3.6.1.4.1.2.6.159.1.1.140.1.1.1
OID = ibmSystemProcessorManufacturer
1.3.6.1.4.1.2.6.159.1.1.140.1.1.2
OID = ibmSystemProcessorUniqueID
1.3.6.1.4.1.2.6.159.1.1.140.1.1.13
OID = ibmSystemProcessorStatus
1.3.6.1.4.1.2.6.159.1.1.140.1.1.15
Disk:
OID = AUSDEVICEINDEX
1.3.6.1.4.1.795.14.1.400.1.1.1
OID = ausDeviceUniqueId
1.3.6.1.4.1.795.14.1.400.1.1.2
OID = ausDeviceTypeGroup
1.3.6.1.4.1.795.14.1.400.1.1.5
OID = ausDeviceVendor
1.3.6.1.4.1.795.14.1.400.1.1.6
OID = ausDeviceModel
1.3.6.1.4.1.795.14.1.400.1.1.7
OID = ausDeviceSerialNumber
1.3.6.1.4.1.795.14.1.400.1.1.9
OID = ausDeviceStatus
1.3.6.1.4.1.795.14.1.400.1.1.11
OID = ausStorageDeviceIndex
1.3.6.1.4.1.795.14.1.410.1.1.1
OID = ausStorageDeviceFormattedCapacity
1.3.6.1.4.1.795.14.1.410.1.1.3
Raid controller:
OID = AUSCONTROLLERINDEX
1.3.6.1.4.1.795.14.1.201.1.1.1
OID = ausControllerUniqueId
1.3.6.1.4.1.795.14.1.201.1.1.2
OID = ausControllerVendor
1.3.6.1.4.1.795.14.1.201.1.1.3
OID = ausControllerModel
1.3.6.1.4.1.795.14.1.201.1.1.4
OID = ausControllerSerialNumber
1.3.6.1.4.1.795.14.1.201.1.1.6
OID = ausControllerStatus
1.3.6.1.4.1.795.14.1.201.1.1.15
OID = ausArrayIndex
1.3.6.1.4.1.795.14.1.1000.1.1.1
OID = ausArrayName
1.3.6.1.4.1.795.14.1.1000.1.1.2
OID = ausArrayCapacity
1.3.6.1.4.1.795.14.1.1000.1.1.3
OID = ausArrayStatus
1.3.6.1.4.1.795.14.1.1000.1.1.11
IBM WMI poller
Classes polled already by this poller from "root\IBMSD" namespace:
  • CIM_Chassis
  • CIM_NumericSensor
  • IBMPSG_PhysicalMemory
  • IBMPSG_DiskDrive
  • CIM_PowerSupply
  • CIM_Battery
  • IBMPSG_Processor
  • IBMPSG_SystemEnclosure
Verify Source Data on the Server
To verify SNMP OIDs using SNMP Walk :
  1. Remote Desktop to the Orion Server
  2. Open SNMPwalk.exe in the Orion installation directory. (The default path is C:\Program Files (x86)\Solarwinds\Orion)
  3. Fill out the IP Address and Community String
  4. Click Scan
  5. Search the resulting file for the OIDs listed above for the related vendor.
To verify WMI Pollers using WBEMTEST :
  2. Run > wbemtest
  3. Connect
  4. Namespace: (Differs based on Vendor from above)
    \\IPAddressofTargetServer\root\HPQ
    \\IPAddressofTargetServer\root\cimv2\dell
    \\IPAddressofTargetServer\root\IBMSD
  5. Provide credentials under User and Password.
  6. Leave Authority blank
  7. Click Connect
  8. Click Query
  9. Generate a query based on the classes from above to verify the information.
    Example:
    SELECT * FROM CIM_Chassis
URLs used by SolarWinds to poll Warranty information.
HP : https://support.hpe.com/hpsc/wc/public/home
Dell: https://www.dell.com/support/home/en-ph
IBM: The warranty information moved from IBM website to Lenovo website. https://support.lenovo.com/us/en/systemxwarrantylookup
