Applications Systems
Deep Dive on Using AppInsight Templates in SAM - Webinar
Watch this video to learn about using AppInsight™ templates in Server & Application Monitor (SAM) to monitor business-critical applications in your environment, including Microsoft Active Directory, Exchange, IIS, and SQL. (54:16)
5/8/2019 10:11 PM
11/12/2026 6:54 PM
If you own SolarWinds SAM and haven’t interacted with Will Muhle, you should not miss this webinar! Will is a senior sales engineer, but before moving into this role, he was an application engineer at SolarWinds. He’ll explain how to configure and use the AppInsight templates that are available for Microsoft IIS, Active Directory, SQL, and Exchange.
Learn More
Server Application Monitor
