Configuration Wizard fails after Log Analyzer installation
When configuring Log Analyzer, the Configuration Wizard fails during database configuration.
You can find the following in the Configuration Wizard logs:
ERROR DBConfigProcessor - Error while executing script - Incorrect syntax near '$.Id'.. Error details: System.Data.SqlClient.SqlException (0x80131904): Incorrect syntax near '$.Id'. (...) Failing Sql command: CREATE VIEW [dbo].[Support_OrionLog_LogRuleFieldsView] AS SELECT (...)
The information can be confirmed using Database Manager and running the query below:
SELECT compatibility_level FROM sys.databases WHERE name = '<DatabaseName>'
- Make a backup of the database.
- Using SQL Management Studio, execute the query below:
ALTER DATABASE <DatabaseName> SET COMPATIBILITY_LEVEL = 130
- Run the Configuration Wizard again.
