Primary or Additional Polling Engine is polling a deleted node in the Orion Platform
This article addresses an issue that causes either the Main Polling Engine or an Additional Polling Engine (APE) to poll a deleted node.
11/7/2018 5:27 PM
9/8/2021 4:15 PM
After you delete a node and generate a WinPcap or Wireshark log, the log states that the Orion server polled information on the deleted node. The Orion Web Console does not display the deleted node.
Network Performance Monitor
Older versions had a bug with clearing sdf cache.
Clear the Cache
  1. Stop Orion services, as described in Start and stop Orion services.
  2. Repair the services on the following systems.
    • Orion servers
    • Additional Polling Engines
    • Additional Web Servers
  3. Open the SolarWinds Orion Database Manager.
  4. Click Add default server.
  5. Right-click Orion Database and select New Query.
  6. Enter the following queries:
    Delete From [dbo].[PendingNotifications]
    Delete From [dbo].[SubscriptionTags]
    Delete From [dbo].[Subscriptions]
  7. Click Execute query.
  8. Start and stop Orion services on the following systems:
    • Orion servers
  1. On the Orion server, navigate to:
    C:\ProgramData\SolarwWinds\Installers
  2. Locate the following .msi(s) (double-click or right-click to uninstall and reinstall):
    • Jobengine (does not exist in newer versions of Orion)
    • Jobenginev2 (file will begin with JOBENGINE) Latest modified file
    • Collector (file will begin with COLLECTOR) Latest modified file
  3. Uninstall these services.
  4. When finished, reinstall these services.
  5. Run the Orion Configuration Wizard to refresh Orion files.
