A Network Node was not selected
This article describes an issue where a message on the Node Details or custom properties pages read: "A Network Node was not selected"
Sample Images:
The Node Status may also say Node is Unknown.
1. The node has an incorrect polling EngineID.
2. Problem with one or multiple of the Web Servers.
Resolution1:
Using the Orion Database Manager:2. Open Database manager - Add default server - find your Solar Winds database - find the table "AllEngines" and double click on it, execute the default query "SELECT TOP 1000 * FROM [dbo].[AllEngines]"
3. Check the NodesData table, and find the EngineID column. You can find it by running this query (you can find the node ID number by going to the node http://YourOrionServer/Orion/NetPerf...?NetObject=N:9)
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT TOP 1000 * FROM [NodesData] WHERE [NodeID] = '9'
5. Verify that it matches a valid poller EngineID. If it does not, correct it and you should be able to monitor the node properly.
NOTE: If you want to see all the nodes where EngineID is not found based on step 1, you can run the following:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT TOP 1000 * FROM [NodesData] WHERE [EngineID] != '1'
Where '1' is returned from the query in step one
Resolution 2:
1. Access each Web Servers URL to identify which Web Server is causing the problem.
2. Restart Orion Services of the affected Web Server/s.
