Tools
550 FTP response code
A 550 response code may be sent in response to any command requiring the server to access a local file. It is a permanent negative response, which means the client is discouraged from sending the command again since the server will respond with the same response code.
This article provides information on 550 FTP response code.
A 550 response code may be sent in response to any command requiring the server to access a local file. It is a permanent negative response, which means the client is discouraged from sending the command again since the server will respond with the same response code. It is usually due to a command requiring access to a file that does not exist or that the user does not have access rights to.
Example response
550 Requested action not taken; file unavailable.
