Tools
504 FTP response code
A 504 response code can be sent in response to any command using a parameter that is not supported by the server. It is a permanent negative response, which means the client is discouraged from sending the command again since the server will respond with the same response code. Issuing the same command with a different parameter may result in a different response code.
10/25/2018 7:51 PM
10/25/2018 7:51 PM
This article provides information on 504 FTP response code.
Example response
504 Command not implemented for that parameter.
Possible commands
