Tools
202 FTP response code
This article explains why the 202 FTP response code is sent.
10/24/2018 8:07 PM
10/24/2018 8:07 PM
This article desribes why the 202 FTP response code is sent.
A 202 response is meant to indicate that the command is recognized but not implemented by the server because it has no use or meaning to the server. It is considered a successful reply because the client can continue its FTP transaction as if the command was successfully completed on the server.
Example response
202 Command not implemented, superfluous at this site.
Possible commands
