Tools
How to set a custom path for the DRE Technician Console
This article outlines instructions for changing the default installation path for the DRE Technician Console.
- Download the DRE console installer on the target device.
- Login to the Admin Area.
- Go to Downloads.
- Download the Technician Console.
- Run the Console installer through the Windows Command Prompt, as follows:
- <path to the console installer> /D=<custom path>
- Replace <custom path> with the intended install path.
