Wireless Summary view in Orion displays duplicate access points
This article troubleshoots an issue that causes duplicate access points for Cisco wireless LAN controllers (WLC) to display in the Wireless Summary view.
Set one WLC to ICMP and clean up the database to remove the access points.
- Back up your database.
- Open Database Manager.
- Click Add default server.
- Right-click the Orion database.
- Click New Query.
- Paste the following into the query:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. DELETE FROM Wireless_Clients WHERE NodeID= The Devices NodeID for the ICMP Device DELETE FROM Wireless_Interfaces WHERE NodeID= The Devices NodeID for the ICMP Device DELETE FROM Wireless_AccessPoints WHERE NodeID= The Devices NodeID for the ICMP Device DELETE FROM Wireless_Controllers WHERE NodeID= The Devices NodeID for the ICMP Device
- Click Execute query.
