Applications Systems
Widget changes are not saved after changing dashboards
After editing and filtering a widget, the changes are not saved after changing dashboards.
11/15/2018 9:14 PM
11/15/2018 9:14 PM
Virtualization Manager
Perform the following steps to restore the dashboard to default settings.
  1. Go to Explore > Content.
  2. Click Filter by Type > Dashboards.
  3. Select the affected dashboard and click Restore Defaults.
