MSP
Why SolarWinds Products are not affected by CVE-2026-18577, CVE-2026-86206, CVE-2026-86207, and CVE-2026-86218
This article explains why SolarWinds products are not affected by CVE-2026-18577, CVE-2026-86206, CVE-2026-86207, and CVE-2026-86218.
9/9/2026 6:01 PM
9/9/2026 6:01 PM
In 2026, the National Institute of Standards and Technology (NIST) published a security bulletin about CVE-2026-18577,  CVE-2026-86206, CVE-2026-86207, and CVE-2026-86218, vulnerabilities affecting the N-able N-central application.
MSP
CVE-2026-18577 is an authentication bypass vulnerability affecting the N-able N-central application up to version 2026.3.1.
CVE-2026-86206 is an unauthorized access vulnerability affecting the N-able N-central application running on versions earlier than 2026.3.1.13.
CVE-2026-86207 is another authentication bypass vulnerability affecting the N-able N-central application that leads to internal API access. Versions earlier than 2026.3.1.13 are affected.
CVE-2026-86218 is a pre-authentication remote code execution vulnerability affecting the N-able N-central application. Versions earlier than 2026.3.1.14 are affected.
SolarWinds products do not use the N-able N-central application, and SolarWinds and N-able are separate, independently operated companies.
