Why SolarWinds Observability Self-Hosted is not affected by multiple OpenSSL 3.0.19 vulnerabilities
This article explains why SolarWinds Observability Self-Hosted is not affected by the following OpenSSL vulnerabilities: CVE-2026-45447 CVE-2026-7383 CVE-2026-28387 CVE-2026-9076 CVE-2026-63076 CVE-2026-63072 CVE-2026-54874 CVE-2026-45445 CVE-2026-34180 CVE-2026-31790 CVE-2026-28390 CVE-2026-28389 CVE-2026-28388 CVE-2026-63074 CVE-2026-42767 CVE-2026-42766 CVE-2026-45446 CVE-2026-42770 CVE-2026-54872 CVE-2026-75805 CVE-2026-75806 CVE-2026-77696 CVE-2026-84782
11/16/2026 9:13 PM
11/16/2026 9:13 PM
In 2026, the National Institute of Standards and Technology (NIST) published security bulletins about the following OpenSSL vulnerabilities:
NVD-CVE-2026-45447
NVD-CVE-2026-7383
NVD-CVE-2026-28387
NVD-CVE-2026-9076
NVD-CVE-2026-63076
NVD-CVE-2026-63072
NVD-CVE-2026-54874
NVD-CVE-2026-45445
NVD-CVE-2026-34180
NVD-CVE-2026-31790
NVD-CVE-2026-28390
NVD-CVE-2026-28389
NVD-CVE-2026-28388
NVD-CVE-2026-63074
NVD-CVE-2026-42767
NVD-CVE-2026-42766
NVD-CVE-2026-45446
NVD-CVE-2026-42770
NVD-CVE-2026-54872
NVD-CVE-2026-75805
NVD-CVE-2026-75806
NVD-CVE-2026-77696
NVD-CVE-2026-84782
Orion Platform
CVE-2026-45447 is a use-after-free vulnerability in the OpenSSL PKCS#7 signature verification implementation. When processing a specially crafted PKCS#7 or S/MIME signed message containing an empty digestAlgorithms field, OpenSSL may incorrectly free a BIO object owned by the calling application. Subsequent use of the BIO can result in a process crash, heap corruption, or potentially remote code execution. Applications using the OpenSSL PKCS#7 for verification APIs may be affected.
CVE-2026-7383 is a heap buffer overflow vulnerability in the OpenSSL ASN.1 multibyte string conversion functions. An integer overflow when calculating the destination buffer size for Unicode string conversion can result in an undersized memory allocation followed by an out-of-bounds write. Depending on the application and memory layout, this can cause a crash or potentially allow arbitrary code execution. Exploitation requires extremely large attacker-controlled input and applications using the affected conversion functions directly.
CVE-2026-28387 is a use-after-free vulnerability in the OpenSSL DANE TLS client implementation. Under an uncommon combination of DANE TLSA certificate usages, processing specially configured TLSA records from a remote server can trigger a use-after-free or double-free condition. This may result in memory corruption, application crashes, or potentially arbitrary code execution. The vulnerability requires the client to support multiple specific DANE certificate usages and communicate with a server publishing matching TLSA records.
CVE-2026-9076 is an out-of-bounds read vulnerability in theOpenSSL CMS password-based decryption implementation. When processing a specially crafted CMS message, an attacker can select a stream-mode key-encryption cipher that causes OpenSSL to perform an insufficient buffer-length check during key unwrapping. This can result in reading memory beyond the allocated buffer and potentially crash the application. Applications processing untrusted CMS messages using password-based decryption APIs may be affected.
CVE-2026-63076 is a denial-of-service (DoS) vulnerability in the OpenSSL Certificate Management Protocol (CMP) implementation. When verifying password-based message protection, OpenSSL fails to properly validate the ASN.1 parameter type before interpreting it as a password-based MAC parameter. A specially crafted CMP message can therefore trigger an invalid pointer dereference and crash the application. Remote unauthenticated attackers may exploit this vulnerability against CMP servers accepting password-protected messages or clients communicating with malicious CMP servers
CVE-2026-63072 is an out-of-bounds heap write vulnerability in the OpenSSL CMS decryption implementation. When processing a specially crafted CMS message using AES-WRAP-PAD key unwrapping, OpenSSL incorrectly calculates the required output buffer size. This can cause an 8-byte out-of-bounds heap write, resulting in memory corruption and potentially a denial of service. Applications processing attacker-controlled CMS messages through the CMS_decrypt() function may be affected.
CVE-2026-54874 is a denial-of-service vulnerability in the OpenSSL DTLS implementation. During an ongoing DTLS handshake, receiving records belonging to a future encryption epoch causes OpenSSL to buffer significantly more memory than the actual record requires. A remote peer can exploit this behavior by sending relatively small amounts of network traffic, causing disproportionate memory consumption on the receiving endpoint. Repeated exploitation can exhaust available memory and potentially make the DTLS service unavailable.
CVE-2026-45445 is a cryptographic vulnerability in the OpenSSL AES-OCB implementation. When an application uses the one-shot EVP_Cipher() interface, the supplied initialization vector (IV) is silently ignored. As a result, messages encrypted with the same key use the same effective nonce, potentially compromising confidentiality. Additionally, authentication tags may become independent of the actual plaintext or ciphertext, allowing an attacker to forge arbitrary ciphertexts after capturing a single valid message. The vulnerability only affects applications using AES-OCB through the EVP_Cipher() interface.
CVE-2026-34180 is a heap buffer over-read vulnerability in the OpenSSL ASN.1 decoding implementation. Processing a specially crafted DER-encoded ASN.1 structure containing a primitive element larger than 2 GB can trigger an integer truncation when calculating the content length. This can cause OpenSSL to read beyond the allocated input buffer, potentially resulting in an application crash or unintended access to adjacent memory contents. Applications decoding attacker-controlled ASN.1 data using the OpenSSL d2i_* functions may be affected.
CVE-2026-31790 is an information disclosure vulnerability in the OpenSSL RSA Key Encapsulation Mechanism (RSA-KEM) implementation. When performing RSA Secret Value Encapsulation (RSASVE), OpenSSL incorrectly handles encryption failures and may report a successful operation even when RSA encryption has failed. This can result in an uninitialized or stale memory buffer being returned as the encapsulated ciphertext. If an application processes an attacker-controlled invalid RSA public key without first validating it, sensitive data from previously used memory may be disclosed to the attacker.
CVE-2026-28390 is a denial-of-service vulnerability in the OpenSSL CMS decryption implementation. When processing a specially crafted CMS EnvelopedData message using RSA-OAEP encryption and KeyTransportRecipientInfo, OpenSSL fails to check whether an optional RSA-OAEP parameters field is present before accessing it. An attacker can exploit this behavior by supplying a malformed CMS message, triggering a NULL pointer dereference and crashing the application. Applications processing untrusted CMS messages through CMS_decrypt() may be affected.
CVE-2026-28389 is a denial-of-service vulnerability in theOpenSSL CMS decryption implementation. When processing a specially crafted CMS EnvelopedData message using KeyAgreeRecipientInfo, OpenSSL fails to validate the presence of an optional key-encryption algorithm parameters field before accessing it. An attacker can exploit this behavior by supplying a malformed CMS message, triggering a NULL pointer dereference and causing the application to crash. Applications processing untrusted CMS messages through CMS_decrypt() may be affected.
CVE-2026-28388 is a denial-of-service vulnerability in the OpenSSL X.509 certificate revocation list (CRL) processing implementation. When processing a specially crafted delta CRL containing a Delta CRL Indicator extension but missing the required CRL Number extension, OpenSSL may attempt to dereference a NULL pointer. This can cause the application to crash. Exploitation requires delta CRL processing to be enabled and the application to process a malformed CRL.
CVE-2026-63074 is a denial-of-service vulnerability in the OpenSSL Certificate Management Protocol (CMP) implementation. When a CMP server processes rejected messages containing additional certificates (extraCerts), OpenSSL fails to properly clear the cached certificate data. A remote attacker can repeatedly submit messages containing unique certificates, causing unbounded memory consumption and potentially exhausting available memory. The vulnerability particularly affects CMP servers that reuse the same OSSL_CMP_CTX for their entire lifetime.
CVE-2026-42767 is a denial-of-service vulnerability in the OpenSSL Certificate Management Protocol (CMP) client implementation. When processing a specially crafted CMP response containing a CRMF EncryptedValue structure with a missing algorithm parameters field, OpenSSL may attempt to dereference a NULL pointer. A malicious or compromised CMP server, or an attacker performing a man-in-the-middle attack, can exploit this behavior to crash the CMP client application.
CVE-2026-42766 is a denial-of-service vulnerability in the OpenSSL CMS password-based decryption implementation. When processing a specially crafted password-encrypted CMS message, OpenSSL fails to validate the presence of the optional key derivation algorithm field before accessing it. An attacker can exploit this behavior by supplying a malformed CMS message, triggering a NULL pointer dereference and causing the application to crash. Applications processing password-encrypted CMS messages may be affected.
CVE-2026-45446 is an authentication bypass vulnerability in the OpenSSL AES-SIV and AES-GCM-SIV implementations. When decrypting an empty ciphertext containing attacker-controlled Additional Authenticated Data (AAD), OpenSSL may fail to properly recalculate the expected authentication tag. In AES-GCM-SIV, this can allow an attacker to construct an empty ciphertext with arbitrary AAD and an all-zero authentication tag that is accepted as valid without knowing the encryption key. This can allow an attacker to bypass message authentication in applications using the affected encryption modes.
CVE-2026-42770 is a cryptographic vulnerability in the OpenSSL finite-field Diffie-Hellman (FFC-DH) key exchange implementation. When validating an X9.42 DHX peer key, OpenSSL incorrectly performs subgroup membership validation using the peer-supplied subgroup parameter q instead of the locally configured value. A malicious peer can exploit this weakness by providing specially crafted domain parameters and public values, potentially recovering the victim's private key after a relatively small number of key exchange attempts.
CVE-2026-54872 is a timing side-channel vulnerability in the OpenSSL elliptic-curve cryptographic implementation. Generic elliptic-curve scalar multiplication used for ECDSA and SM2 signature operations on curves without dedicated constant-time implementations can expose information about the secret signing nonce through variations in execution time. By collecting and analyzing a sufficiently large number of signing measurements, an attacker may be able to recover the private signing key using lattice-based cryptanalysis.
CVE-2026-75805 is a denial-of-service vulnerability in the OpenSSL Certificate Management Protocol (CMP) client implementation. When a CMP client requests certificate revocation using a PKCS#10 certificate signing request, a specially crafted revocation response can trigger a NULL pointer dereference during response processing. A malicious or compromised CMP server, or an attacker with valid message protection credentials, can exploit this behavior to crash the client application.
CVE-2026-75806 is a denial-of-service vulnerability in the OpenSSL DTLS 1.2 implementation. When an established DTLS association uses an authenticated encryption with associated data (AEAD) cipher suite, OpenSSL fails to validate whether an incoming encrypted record is long enough to contain the required explicit initialization vector and authentication tag. An unauthenticated attacker who can send a datagram to an existing DTLS association can exploit this behavior to terminate the connection without knowing any encryption keys.
CVE-2026-77696 is a timing side-channel vulnerability in the OpenSSL SM2 digital signature implementation. During SM2 signature generation, OpenSSL performs variable-time arithmetic operations on secret values, causing signature generation time to depend on the private key and secret signing nonce. An attacker capable of measuring the execution time of a sufficiently large number of signing operations may be able to reconstruct the private signing key through statistical and lattice-based analysis.
CVE-2026-84782 is an out-of-bounds memory access vulnerability in the OpenSSL DTLS retransmission implementation. When a DTLS handshake message write is suspended before completion, the retransmission mechanism may incorrectly access the message buffer and overwrite internal state required to resume the original operation. A remote attacker can potentially trigger this condition during handshake retransmissions, resulting in disclosure of heap memory contents or a denial of service through an application crash.
SolarWinds Observability Self-Hosted is not affected CVE-2026-31789, CVE-2026-75803, CVE-2026-34182, CVE-2026-45447, CVE-2026-7383, CVE-2026-28387, CVE-2026-9076, CVE-2026-63076, CVE-2026-63072, CVE-2026-54874, CVE-2026-45445, CVE-2026-34180, CVE-2026-31790, CVE-2026-28390, CVE-2026-28389, CVE-2026-28388, CVE-2026-63074, CVE-2026-42767, CVE-2026-42766, CVE-2026-45446, CVE-2026-42770, CVE-2026-54872, CVE-2026-75805, CVE-2026-75806, CVE-2026-77696, CVE-2026-84782.
CVE-2026-45447: SolarWinds Observability Self-Hosted does not use the affected OpenSSL PKCS7_verify() functionality. The vulnerable PKCS#7 signature verification code path is not used by the product and is therefore not in its execution path.
CVE-2026-7383: SolarWinds Observability Self-Hosted does not directly use the affected OpenSSL ASN1_mbstring_copy(), ASN1_mbstring_ncopy(), or ASN1_STRING_TABLE_add() functions. The vulnerable ASN.1 multibyte string conversion functionality is not used by the product and is therefore not in its execution path.
CVE-2026-9076, CVE-2026-63072, CVE-2026-28390, CVE-2026-28389, CVE-2026-42766: SolarWinds Observability Self-Hosted does not use the affected OpenSSL CMS (Cryptographic Message Syntax) functionality. CMS message processing and decryption operations associated with these vulnerabilities are not used by the product and are therefore not in its execution path.
CVE-2026-63074, CVE-2026-42767, CVE-2026-63076, CVE-2026-75805: SolarWinds Observability Self-Hosted does not use the affected OpenSSL Certificate Management Protocol (CMP) functionality. CMP message processing, certificate management, and related operations are not used by the product and are therefore not in its execution path.
CVE-2026-54874, CVE-2026-75806, CVE-2026-84782: SolarWinds Observability Self-Hosted does not use the affected Datagram Transport Layer Security (DTLS) protocol functionality. DTLS connections, handshake processing, and retransmission mechanisms are not used by the product and are therefore not in its execution path.
CVE-2026-28387: SolarWinds Observability Self-Hosted does not use the affected DANE TLSA certificate validation functionality. The vulnerable certificate validation scenarios are not applicable to the product's implementation and are therefore not in its execution path.
CVE-2026-45445: SolarWinds Observability Self-Hosted does not use the affected AES-OCB functionality through the vulnerable OpenSSL EVP_Cipher() interface. Additionally, the OpenSSL advisory explicitly states that TLS is not affected by this vulnerability. The vulnerable functionality is therefore not in the product's execution path.
CVE-2026-34180: SolarWinds Observability Self-Hosted is not affected on the Windows platform, as explicitly stated in the OpenSSL security advisory. The vulnerability does not affect the product's Windows implementation.
CVE-2026-31790: SolarWinds Observability Self-Hosted does not use the affected OpenSSL EVP_PKEY_encapsulate() functionality. The vulnerable RSA Secret Value Encapsulation operation is not used by the product and is therefore not in its execution path.
CVE-2026-28388: SolarWinds Observability Self-Hosted does not enable or use the OpenSSL X509_V_FLAG_USE_DELTAS flag. Delta Certificate Revocation List (CRL) processing associated with this vulnerability is therefore not enabled or used by the product.
CVE-2026-45446: OpenPegasus does not use the affected OpenSSL AES-SIV or AES-GCM-SIV functionality in its protocol implementation. The vulnerable authenticated encryption operations are not used by the product and are therefore not in its execution path.
CVE-2026-42770: OpenPegasus does not use the affected X9.42 Diffie-Hellman (DHX) key exchange functionality. The vulnerable DHX peer-key validation and subgroup verification operations are not used by the product and are therefore not in its execution path.
CVE-2026-54872, CVE-2026-77696: SolarWinds Observability Self-Hosted does not use the specific elliptic-curve cryptographic key types and signing operations affected by these vulnerabilities. The vulnerable ECDSA/SM2 implementation paths are therefore not used by the product.
