Why SolarWinds Observability Self Hosted is not affected by Java4Shell CVE-2026-114938
In 2026, the National Institute of Standards and Technology (NIST) published security bulletins about the following CVE-2026-114938.
n 2026, the National Institute of Standards and Technology (NIST) published a security bulletin about CVE-2026-114938, a vulnerability affecting Spring Framework.
CVE-2026-114938, is a vulnerability in Java that allows an unauthenticated attacker with network access via multiple protocols to compromise Oracle Java SE, Oracle GraalVM for JDK, Oracle GraalVM Enterprise Edition. Successful attacks of this vulnerability can result in takeover of Oracle Java SE, Oracle GraalVM for JDK, Oracle GraalVM Enterprise Edition. Note: This vulnerability can only be exploited by supplying data to APIs in the specified Component without using Untrusted Java Web Start applications or Untrusted Java applets, such as through a web service.
SolarWinds Observability Self-Hosted uses Java 11 which is not affected by the vulnerability.
