Why SolarWinds Observability Self-Hosted is not affected by CVE-2025-13699
This article explains why the SolarWinds Observability Self-Hosted is not affected by CVE-2025-13699.
In 2025, the National Institute of Standards and Technology (NIST) published a security bulletin about CVE-2025-13699.
CVE-2025-13699
The SolarWinds Observability Self-Hosted does not use full MariaDB Server install which is required to be affected by this issue.
The MariaDB ODBC driver (Version 3.2) is used for monitoring MariaDB instances which doesn’t include the affected mariadb-dump utility.
