Database Management
Why SolarWinds Database Performance Analyzer (DPA) is at low risk for CVE-2026-77756
This article explains why SolarWinds Database Performance Analyzer (DPA) is at low risk for CVE-2026-77756.
10/22/2026 12:46 PM
10/22/2026 12:49 PM
In 2026, the National Institute of Standards and Technology (NIST) published a security bulletin about CVE-2026-77756.
CVE-2026-77756 is an inconsistent Interpretation of HTTP Requests ('HTTP Request/Response Smuggling') vulnerability in Apache Tomcat caused by processing the transfer-encoding header for an HTTP/1.0 request may allow an attacker to cause one request from another user to fail when Tomcat is located behind a reverse proxy.
The vulnerability is only possible if all the following conditions are met:
  • DPA is running behind the reverse proxy, API gateway or load balancer
  • If front-end component (reverse proxy, load balancer, API gateway) parses HTTP request framing differently than Tomcat does.
SolarWinds DPA is at a lower risk because it should be running in a trusted network, as per the DPA Secure Configuration Guide: Best Practices and Recommendations.
The worst-case scenario for CVE-2026-77756 on DPA would be causing another client's in-flight request to fail.
