Database Management
Why SolarWinds DPA is not affected by a path traversal vulnerability in functional web frameworks (CVE-2024-38816 and CVE-2024-38819)
This article explains why SolarWinds Database Performance Monitor (DPA) is not affected by CVE-2024-38816 and CVE-2024-38819. These are vulnerabilities in the functional web frameworks WebMvc.fn and WebFlux.fn, which are part of the Spring Framework.
12/9/2024 10:01 PM
7/17/2025 3:21 PM
In 2024, Spring published a description of the following CVEs:
  • CVE-2024-38816
    Applications serving static resources through the functional web frameworks WebMvc.fn or WebFlux.fn are vulnerable to path traversal attacks. An attacker can craft malicious HTTP requests and obtain any file on the file system that is also accessible to the process in which the Spring application is running.
    Specifically, an application is vulnerable when both of the following are true:
    • The web application uses RouterFunctions to serve static resources.
    • Resource handling is explicitly configured with a FileSystemResource location.
    However, malicious requests are blocked and rejected when any of the following is true:
    • The Spring Security HTTP Firewall is in use.
    • The application runs on Tomcat or Jetty
  • CVE-2024-38819
    This is similar to CVE-2024-38816, but with different input.
Database Performance Analyzer
DPA is not affected by CVE-2024-38816 because the application runs on Tomcat. DPA does not use the RouterFunctions feature, which is required for it to be affected by CVE-2024-38819.
Reference links:
CVE-2024-38816: Path traversal vulnerability in functional web frameworks
CVE-2024-38819: Path traversal vulnerability in functional web frameworks (2nd report)
