Tools
Why SolarWinds DPA, SEM, and WHD are not affected by CVE-2025-24813
This article explains why SolarWinds Database Performance Analyzer (DPA), Security Event Manager (SEM), and Web Help Desk (WHD) are not affected by CVE-2025-24813. SolarWinds Database Performance Analyzer (DPA) does not have writes enabled for the default servlet and does not use Apache Tomcat’s file-based session persistence. It is therefore not affected by this vulnerability. SolarWinds Security Event Manager (SEM) also does not have writes enabled for the default servlet and is therefore not affected by this vulnerability. SolarWinds Web Help Desk (WHD) also does not have writes enabled for the default servlet and is therefore not affected by this vulnerability.
3/21/2025 4:42 PM
4/14/2025 3:11 PM
In 2025, the National Institute of Standards and Technology (NIST) published a security bulletin about CVE-2025-24813.
CVE-2025-24813 is a remote code execution vulnerability and/or information disclosure and/or malicious content added to uploaded files via write enabled Default Servlet in Apache Tomcat.
If all the following were true, a malicious user could view security sensitive files and/or inject content into those files:
  • writes enabled for the default servlet (disabled by default)
  • support for partial PUT (enabled by default)
  • a target URL for security sensitive uploads that was a sub-directory of a target URL for public uploads
  • attacker knowledge of the names of security sensitive files being uploaded
  • the security sensitive files also being uploaded via partial PUT
If all the following were true, a malicious user was able to perform remote code execution:
  • application was using Tomcat's file-based session persistence with the default storage location
  • application included a library that may be leveraged in a deserialization attack
This issue affects Apache Tomcat: from 11.0.0-M1 through 11.0.2, from 10.1.0-M1 through 10.1.34, from 9.0.0.M1 through 9.0.98.
The vulnerability described in this CVE affects numerous software companies, but it does not impact SolarWinds Database Performance Analyzer (DPA), Security Event Manager (SEM), and Web Help Desk (WHD).
Web Help Desk
CVE-2025-24813
This vulnerability affects only applications that meet all the pre-requisites mentioned above.
