When adding a node polled by an Orion Remote Collector, UnDPs are not assigned
When you add a node for monitoring by the Orion Platform, specify an Orion Remote Collector (ORC) as the polling engine and assign Universal Device Pollers (UnDPs) to the node, the UnDPs are not assigned. Use an alternative method to assign the UnDPs to the node.
8/25/2020 7:17 AM
8/25/2020 7:17 AM
When you use the Add Node wizard to add a node, select an Orion Remote Collector (ORC) as the polling engine, and select UnDPs on the Add Pollers page, the node is added but the UnDPs are not assigned.
Note: The ORC feature was introduced in Orion Platform 2020.2.1 and requires NAM 2020.2.1.
Orion Platform
The issue is caused by the incorrectly calculated availability of UnDPs on the node.
To work around the issue:
