Applications Systems
What is the difference between Write, Read, and Total Latency on Datastores in VMAN and and how to calculate Total latency on datastores?
5/13/2019 7:31 PM
5/13/2019 7:31 PM
Virtualization Manager
Latency measures the time used to process a SCSI command issued by the guest OS to the virtual machine. The kernel latency is the time VMkernel takes to process an I/O request. The device latency is the time it takes the hardware to handle the request.
In Orion, Total latency is a sum of Read and Write latency.
