What are valid Custom Format options for custom tables?
Review the custom format options for custom tables.
If you are creating a custom table, the following table provides valid entries for the Custom Format option, using an original data value of 12.34567:
| Entry | Description | Example |
{0} unit/% | Returns the unrounded original numerical value | 12.34567 bps or 12.34567 % |
{0:0.00} unit/% | Returns the original numerical value, rounded to the indicated number of decimal places | 12.35 bps or 12.35 % |
0.000 | Returns the original numerical value as a text string, rounded to the indicated number of decimal places | 12.346 |
0.00' bps' | Returns the original numerical value as a text string, rounded to the indicated number of decimal places, concatenated with the string indicated in quotes. | 12.35 bps |
A comprehensive table of valid custom date and time specifiers is available from Microsoft: Custom Date and Time Format Strings
