What are the hardware recommendations for the NTA SQL Flow Storage database?
This article provides hardware recommendations for the NTA SQL Flow Storage database based on the parameters and profile.
For deployment planning, see NTA system requirements.
For information on sizing, see the Orion Multi-module System Guidelines.
For an example configuration, see User scenario: Recommended SQL server disk configuration .
- Click Settings > All Settings.
- Click NTA Settings
- Scroll to "Database Settings"
| PARAMETER | PROFILE 1 | PROFILE 2 |
| Flows per second per poller | 10k | 25k |
| Flows per second per system | 10k | 50k |
| Endpoints count | 10k | 10M |
| Flow sources count | 6 | 100 |
| Nodes | 3 | 20 |
| Interfaces per Node | 2 | 5 |
| Retention period length | 30 days | 30 days |
| Amount of data in the Flow Storage database | Full Retention | Full Retention |
| Top Talker optimization | 95% | 95% |
| Poller count | 1 | 2 |
| IP group segments | 3 | 20 |
| NPM/Core load and utilization | 0 | 0 |
| SQL server instances | 1 | 1 |
Profile 1
If the parameters in your environment match the Profile 1 parameters, review the following hardware recommendations:
- SQL server specifications:
- 32 GB RAM
- 6 core CPU 2.5 GHz
- HDD Seagate ST600MM0006 (600 GB SAS 6 Gb/s 10k RPM) in RAID 0
- Summary loaded in 7 seconds:
- Resource utilization in SQL server for the summary load:
- CPU: 10-50%
- RAM: 4 GB
Profile 2
If the parameters in your environment match the Profile 2 parameters, review the following hardware recommendations:
- 64 GB RAM
- 12 core CPU 2.5 GHz
- Summary loaded in 1 minute 35 seconds:
- CPU: 10-30%
- RAM: 7 GB
