Applications Systems
What NetApp Cluster Mode permissions are required by Storage Resource Monitor
Review the NetApp Cluster Mode permissions required by SolarWinds Storage Resource Monitor (SRM).
10/12/2018 3:04 PM
8/11/2022 6:06 PM
The following permissions are needed for Storage Resource Monitor to gather data from NetApp Cluster mode storage devices. NetApp Cluster mode permissions are related to the CLI commands, which produces the same result and are set based on these. Each user used for monitoring has to be assigned in a role with all required Capabilities.
These API capabilities are required for Cluster Mode. Because permissions are set to the CLI commands, which displays the particular data, the tables below also show command names. These are used to assign permission to the specific API.
API Name
Related CLI command
aggr-get-iter
storage aggregate show
cifs-server-get-iter
vserver cifs show
cifs-share-get-iter
vserver cifs share show
cluster-identity-get
cluster identity show
diagnosis-status-get
system health status show
fcp-initiator-get-iter
vserver fcp initiator show
fcp-interface-get-iter
vserver fcp interface show
igroup-get-iter
lun igroup show
iscsi-initiator-get-iter
vserver iscsi initiator show
iscsi-service-get-iter
vserver iscsi show
lun-get-iter
lun show
lun-map-get-iter
lun mapped show
net-interface-get-iter
network interface show
nfs-exportfs-list-rules-2
vserver export-policy show
perf-object-get-instances
statistics show
quota-report-iter
volume quota report
storage-disk-get-iter
storage disk show
system-get-vendor-info
system node autosupport show
system-get-version
version
volume-get-iter
volume show
vserver-get-iter
vserver show
license-list-info
system license show
license-v2-list-info
system license show
Log in to the NetApp CLI and use the following steps to create a read-only user with sufficient privileges for monitoring the device in SRM.
Required steps summary
  1. Create a new role and assign the specific command privileges under the readonly access level.
  2. Create a monitoring user and assign it to the readonly role.
Detailed Steps
  1. Create a new role and assign the specific command privileges under the readonly access level:
    security login role create -role testrole -cmddirname "security login role show-ontapi" -access readonly
    You can verify, if particular role has a permission assigned with invoking
    security login role show -role testrole
    To assign all permissions listed above, you can copy and paste following text:
    security login role create -role testrole -cmddirname "storage aggregate show" -access readonly
    security login role create -role testrole -cmddirname "vserver cifs show" -access readonly
    security login role create -role testrole -cmddirname "vserver cifs share show" -access readonly
    security login role create -role testrole -cmddirname "cluster identity show" -access readonly
    security login role create -role testrole -cmddirname "system health status show" -access readonly
    security login role create -role testrole -cmddirname "vserver fcp initiator show" -access readonly
    security login role create -role testrole -cmddirname "vserver fcp interface show" -access readonly
    security login role create -role testrole -cmddirname "lun igroup show" -access readonly
    security login role create -role testrole -cmddirname "vserver iscsi initiator show" -access readonly
    security login role create -role testrole -cmddirname "vserver iscsi show" -access readonly
    security login role create -role testrole -cmddirname "lun show" -access readonly
    security login role create -role testrole -cmddirname "lun mapped show" -access readonly
    security login role create -role testrole -cmddirname "network interface show" -access readonly
    security login role create -role testrole -cmddirname "vserver export-policy show" -access readonly
    security login role create -role testrole -cmddirname "statistics show" -access readonly
    security login role create -role testrole -cmddirname "volume quota report" -access readonly
    security login role create -role testrole -cmddirname "storage disk show" -access readonly
    security login role create -role testrole -cmddirname "system node autosupport show" -access readonly
    security login role create -role testrole -cmddirname "version" -access readonly
    security login role create -role testrole -cmddirname "volume show" -access readonly
    security login role create -role testrole -cmddirname "vserver show" -access readonly
    security login role create -role testrole -cmddirname "system license show" -access readonly
    These commands might produce warnings that they will affect other permissions. These warnings can be ignored.
  2. Create the monitoring user from the role:
    security login create -role readonly -username test -application ontapi -authmethod password.
Example
lab-netapp814-clus::> security login create -role readonly -username test -application ontapi -authmethod password
Please enter a password for user 'test':
Please enter it again:
Note: Changing the permissions would require assigning the user to the role again.
CLI commands for Hardware Health polling
NetApp HWH is supported for NetApp Cluster-Mode ONTAP version 9.3 and higher.
The following permissions are needed for hardware health monitoring.
API NAMERELATED CLI COMMAND
system-node-get-itersystem node show
environment-sensors-get-itersystem node environment
 fcp-adapter-get-iternetwork fcp adapter show
net-port-get-iternetwork port show
service-processor-get-itersystem service-processor
storage-shelf-acp-module-get-iter     storage shelf acp module
 storage-shelf-info-get-iter    storage shelf show
ha-interconnect-config-details-get-itersystem ha interconnect config show
To assign all permissions for HWH polling for a role named "labuser", you can copy and paste following text:
security login role create -role labuser -cmddirname "system node environment sensors show" -access readonly
security login role create -role labuser -cmddirname "network fcp adapter show" -access readonly
security login role create -role labuser -cmddirname "network port show" -access readonly
security login role create -role labuser -cmddirname "system service-processor show" -access readonly
security login role create -role labuser -cmddirname "storage shelf acp module show" -access readonly
security login role create -role labuser -cmddirname "storage shelf show" -access readonly
security login role create -role labuser -cmddirname "system node show" -access readonly
security login role create -role labuser -cmddirname "system ha interconnect config show" -access readonly
If these permissions are not assigned, the Hardware Health monitoring page will only show disk information, as shown below.
