Website optimization for initial compilation and caching
This article provides information about the Website Optimization option in the Orion Configuration Wizard.
- Website Optimization occurs on new product installs to perform initial compilation and caching.
- It recompiles files into the Windows .NET Framework temporary files as CS and DLL binaries, and then loads the DLL files itself.
- Each time you run the Orion Configuration Wizard, website optimization also occurs, unless it is skipped.
- SolarWinds recommends that you perform website optimization to prevent slow performance until the page is cached. Subsequent page refreshing should result in a faster page load.
- Run the Orion Configuration wizard.
- When prompted, select Website, and click Next.
- Let the process complete. Do NOT click Skip Website Optimization.
You may also wish to run just the optimization part of it. To do so follow the steps below:
- Open the Command Prompt as Administrator
- Navigate to Orion installation folder (default: C:\Program Files (x86)\SolarWinds\Orion)
- Run the following command
OptimizeWebsite.exe C:\inetpub\SolarWinds
Note: Replace C:\inetpub\SolarWinds with the path of your Orion website.
