Tools
Web Help Desk survey link does not redirect to HTTPS
This article describes how to troubleshoot a Web Help Desk survey link that does not redirect to HTTPS.
11/22/2018 4:45 PM
11/22/2018 4:45 PM
The Web Help Desk survey does not redirect to HTTPS.
Web Help Desk
HTTPS or Redirect to HTTPS is not configured properly.
Edit the whd.conf file and modify the port parameters.
  1. Log in to the Web Help Desk Administrator Console as an administrator.
  2. Go to Setup > General > Options.
  3. Select the Force to HTTPS checkbox, and click Save.
  4. Under General, select Server Options.
  5. Make sure the following server options are enabled, and click Save:
    • HTTP
    • HTTPS
    • Redirect HTTP Requests to HTTPS
  6. Log in to the Web Help Desk server.
  7. Navigate to your Web Help Desk home directory.
    Apple® OS X:  /Library/WebHelpDesk
    Microsoft® Windows®:   \Program Files\WebHelpDesk
    Red Hat®/CentOS™ /Fedora Linux: /usr/local/webhelpdesk
  8. Open the /conf directory.
  9. Open the whd.conf file in a text editor (such as Notepad).
  10. Locate the PORTS section in the file.
  11. In the file, make the following changes: < ====================== # PORTS DEFAULT_PORT=8081 HTTPS_PORT=8443 (Note: Set the correct port that you are using.) ====================== # NO REDIRECT TO HTTPS #NO_REDIRECT=true ====================== >
  12. Save the file.
  13. Stop and start Web Help Desk.
