Tools
Web Help Desk generates an error message after an upgrade
This article addresses an error message that displays after you initiate a Web Help Desk upgrade using a remote system
After you initiate a Web Help Desk upgrade from a remote system and log in to the application, the following message displays:
An update to the help desk is in progress.
Please come back in a few minutes.
Complete the upgrade from the Web Help Desk console.
- Log in to the Web Help Desk Admin Console as an administrator.
A message displays, prompting you to complete the upgrade. - Click OK to complete the upgrade.
Update the whd.conf file
To avoid this issue during the next upgrade, update the whd.conf file in your Web Help Desk home directory to allow the server to log in to the Web Help Desk Admin Console automatically and complete the upgrade.
SolarWinds strongly recommends that you edit the whd.conf file only as instructed. Any additional modifications may result in system performance issues or may create an error state.
- Log in to the Web Help Desk server as an administrator.
- Stop Web Help Desk.
- Navigate to your Web Help Desk home directory.
- Apple OSX:
/Library/WebHelpDesk - Microsoft Windows: \
Program Files\WebHelpDesk - Linux:
/user/local/webhelpdesk
- Apple OSX:
- In the home directory, open the
confdirectory. - Back up the
whd.conffile to a separate directory. - Open the
whd.conffile in a text editor. - In the file, locate
PRIVILEGED_NETWORKS. - Add the Web Help Desk server IP address as a privileged network.
- Save your changes.
- Start Web Help Desk.
