Tools
Web Help Desk Continuously Sending Email
Web Help Desk is continuously sending email updates of a ticket updates that are happening every minute on a specific ticket(s).
Tools
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third-party content at your own risk, and you will be solely responsible for the incorporation of the same if any.
Solarwinds offers fully functional free trials of all of our products, from network and systems management to IT Security and Database Monitoring
