Tools
Web Help Desk 2026.1 – Unable to Attach Files Using Google Chrome or Microsoft Edge
When attempting to attach a file in Web Help Desk (WHD), clicking the Choose File button in the pop-up window does not open File Explorer. The issue may be temporarily resolved by resizing the pop-up window.
After updating their browsers to the versions listed below, users may experience an issue where clicking the Choose File button in the WHD attachment pop-up window does not respond or open File Explorer.
This issue occurs unless the pop-up window is manually resized.
Affected Browser Versions:
- Google Chrome: 157.0.8103.39 (Official Build) (64-bit)
- Microsoft Edge: 157.0.4341.42 (Official Build) (64-bit)
The file chooser dialog is suppressed because the top-level browser window is smaller than the minimum required size of 400 x 300 pixels.
There are three possible workarounds for this issue.
Option 1: Modify the Browser Shortcut Target
You can disable the FileChooserMinWindowSize feature by modifying the Target field in your Google Chrome or Microsoft Edge desktop shortcut.
For Google Chrome:
- Right-click the Google Chrome shortcut icon on your desktop and select Properties.
- Under the Shortcut tab, locate the Target field.
- Update the Target field by adding the following parameter after the closing quotation mark, separated by a space:
--disable-features=FileChooserMinWindowSize
Original Target:
"C:\Program Files\Google\Chrome\Application\chrome.exe" --source-shortcut-location=desktop
Updated Target:
"C:\Program Files\Google\Chrome\Application\chrome.exe" --disable-features=FileChooserMinWindowSize --source-shortcut-location=desktop
For Microsoft Edge:
Follow the same steps using your Microsoft Edge desktop shortcut.
Original Target:
"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --source-shortcut-location=desktop
Updated Target:
"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --disable-features=FileChooserMinWindowSize --source-shortcut-location=desktop
Note: Make sure the parameter is added after the closing quotation mark, with a space before it.
- Click Apply, then OK to save the changes.
- Close all currently open browser windows.
- Reopen the browser using the modified desktop shortcut.
- Open Web Help Desk and test the Choose File button again.
Option 2: Resize the Pop-up Window
As an alternative workaround, manually resize the attachment pop-up window in Google Chrome or Microsoft Edge. Once resized, try clicking the Choose File button again.
Option 3: Use Mozilla Firefox
You may also use Mozilla Firefox as an alternative browser. This issue has not been observed in Firefox, including its latest version.
