Tools
Web Help Desk 12.7.8 Hotfix 2 Release Notes
This article describes how to install Web Help Desk 12.7.8 Hotfix 2 on your Web Help Desk server.
- Prevents manipulation of the Database backup command. This command is now configured as the following JVM variable: DWHDdatabaseBackupCommand
- Adds access logs
- Addresses the Spring Framework Vulnerability
- spring-aop.jar
- spring-beans.jar
- spring-context.jar
- spring-context-support.jar
- spring-core.jar
- spring-expression.jar
- spring-jcl.jar
- spring-jdbc.jar
- spring-jms.jar
- spring-messaging.jar
- spring-orm.jar
- spring-test.jar
- spring-tx.jar
- spring-web.jar
- spring-webmvc.jar
- whd-core.jar
- whd-persistence.jar
- whd-web.jar
- tomcat_server_template.xml
- logger.jar
See SolarWinds Product Checksums for SHA256, SHA1, and MD5 values.
NOTE: In the installation instructions, <WebHelpDesk> represents the Web Help Desk home folder. The default home folders for the supported operating systems are listed below.
| Operating System | Path |
| macOS | /Library/WebHelpDesk |
| Microsoft Windows | \Program Files\WebHelpDesk |
| Linux | /usr/local/webhelpdesk |
SolarWinds CVEs
| CVE-ID | Vulnerability Title | Description | Severity |
| CVE-2022-22965 | Spring4Shell Vulnerability | Spring Framework remote code execution (RCE) vulnerability | Critical |
Download this hotfix
- Log in to the Web Help Desk server as an administrator.
- Open a Web browser, navigate to the SolarWinds Customer Portal, and log in.
- Click Downloads and select Hotfixes.
- Click the View Hot Fixes for License drop-down menu and select Web Help Desk Per Seat License.
- Download Web Help Desk v12.7.8 - Hot Fix 2.
Install this hotfix
- Stop Web Help Desk.
- Navigate to the following directory:
- <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/lib/
- Back up the following files to a separate directory:
- spring-aop.jar
- spring-beans.jar
- spring-contect.jar
- spring-core.jar
- spring-jcl.jar
- spring-jdbc.jar
- spring-jms.jar
- spring-orm.jar
- spring-test.jar
- spring-tx.jar
- spring-web.jar
- spring-webmvc.jar
- whd-core.jar
- whd-web.jar
- Copy the files included with this hotfix to the /lib directory, overwriting the following files:
- spring-aop.jar
- spring-beans.jar
- spring-core.jar
- spring-jcl.jar
- spring-jdbc.jar
- spring-orm.jar
- spring-test.jar
- spring-tx.jar
- spring-web.jar
- spring-webmvc.jar
- whd-core.jar
- whd-web.jar
- <WebHelpDesk>/conf/
- Copy the file included with this hotfix to the /conf directory, overwriting the following file:
- <WebHelpDesk/bin/tomcat/lib/
- Copy the file included with this hotfix to the /bin/tomcat/lib directory:
- logger.jar
- Start Web Help Desk. The hotfix is installed.
Uninstall this hotfix
- Copy your backup files to the /lib directory, overwriting the following files:
- spring-aop-jar
- spring-beans.jar
- spring-core.jar
- spring-jcl.jar
- spring-jdbc.jar
- spring-jms.jar
- spring-orm.jar
- spring-test.jar
- spring-tx.jar
- spring-web.jar
- spring-webmvc.jar
- whd-core.jar
- whd-web.jar
- Copy your backup file to the /conf directory, overwriting the following file:
- Start Web Help Desk. The hotfix is uninstalled.
